CalG
Super Member
- Joined
- Sep 29, 2011
- Messages
- 9,321
- Location
- vermont
- Tractor
- Hurlimann 435, Fordson E27n, Bolens HT-23, Kubota B7200, Kubota B2601
I have two tractors, well three if you count the Bolens HT23.
Both the Fordson E27n and the Hurlimann Prince 435 have two pin Auxiliary electrical sockets fitted from the factory . (They are different however).
These are smallish sockets, about an inch in diameter, plugs for extra lights, trailers, heated clothing etc. less than 10amps, I am sure
But where does one find the matching plugs?
The Fordson is an antique, and I can appreciate the dated nature of the matching parts. The Hurlimann is so poorly supported by the dealer network in this area that there is no one to ask, plus the location of the socket is just about the most difficult spot to get to. (Shoot that design engineer;-) Have you ever tried to measure something you can only see with a mirror? ;-)
The most promising match for the Hurlimann is a product from Cole-Hersee Co. in Boston MA p/n 11042-05, but no dimensions are given. I could purchase both socket and plug and just make a clean break from the original.
I would like to use the socket on the Hurlimann to power my electric vest for winter snow removal, as well as have a convenient plug for connecting a battery charger or trouble light. The battery access is complicated by the loader frame.
For the Fordson. fitted with a front mount snow plow, I just want to fit a LED work light to illuminate the things I'm going to run into while baking up. That way I can better describe to my wife why I had to stop moving snow and come in for a hot cup of tea ;-)
If anyone has a good source for two pin low voltage plugs, please advise.
Newark electronics...here I come.
Cheers and TIA
Cal
in Vermont
Cheers and TIA
Cal
in Vermont
