Automatic start
/ Automatic start #1
1930
Platinum Member
Brandon/Ocala Florida
Kubota B6100E Kubota L 2501 Kubota T1460
Is it possible to have a gas powered lawn mower engine start itself via its electric starter and charge its own battery at a pre determined point of battery discharge
In other words I want to keep a battery that I use to run a pump charged to a safe level versus discharge it to a point of damaging the battery.
Lawn mower engines are affordable
If I could have something monitor the battery and recharge at a safe point than I will have accomplished what I need to have happen
Thanks
/ Automatic start #2
Cheaper and more effective to use a battery maintainer if power is available, if not then use a solar battery maintainer. Besides using a small gas engine means keeping up with the fuel and oil which to me is no different than manually checking the battery.
/ Automatic start
Power not available and solar will never keep up with usage
/ Automatic start #4
It certainly can be done. I'd expect that reliability would be a driving cost.
Could be as low as;
Voltage Detection Module Relay Switch Charging Discharge Monitoring Protection | eBay
Or a few dollars more;
/ Automatic start #5
So you are running a pump heavily and the only power is battery?
Might a small generator be a better starting point? That would give you the motor and generating piece of it. The monitor/trigger part might be tougher, but you could deal with some of the things Lou listed above, perhaps. Maybe more serious solar with batteries would be a solution?
/ Automatic start #7
That's as funny as all get-out. :ROFLMAO:
I like the spuing diesel MOX.
Craftsmen 3400 PSI Pressure Washer (A65579)
Craftsmen 3400 PSI...
Mini Skid Steer Mount Plate, 5/16" Thickness (A62679)
Mini Skid Steer...
6x12 Leonard Utility Trailer (A65579)
6x12 Leonard...
Hedge Posts (A65640)
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
Land Pride RB3584 3-Pt Blade (A66408)
Land Pride RB3584...
