Automatic start
/ Automatic start #1
1930
Platinum Member
Brandon/Ocala Florida
Kubota B6100E Kubota L 2501 Kubota T1460
Is it possible to have a gas powered lawn mower engine start itself via its electric starter and charge its own battery at a pre determined point of battery discharge
In other words I want to keep a battery that I use to run a pump charged to a safe level versus discharge it to a point of damaging the battery.
Lawn mower engines are affordable
If I could have something monitor the battery and recharge at a safe point than I will have accomplished what I need to have happen
Thanks
/ Automatic start #2
Cheaper and more effective to use a battery maintainer if power is available, if not then use a solar battery maintainer. Besides using a small gas engine means keeping up with the fuel and oil which to me is no different than manually checking the battery.
/ Automatic start
Power not available and solar will never keep up with usage
/ Automatic start #4
It certainly can be done. I'd expect that reliability would be a driving cost.
Could be as low as;
Voltage Detection Module Relay Switch Charging Discharge Monitoring Protection | eBay
Or a few dollars more;
/ Automatic start #5
So you are running a pump heavily and the only power is battery?
Might a small generator be a better starting point? That would give you the motor and generating piece of it. The monitor/trigger part might be tougher, but you could deal with some of the things Lou listed above, perhaps. Maybe more serious solar with batteries would be a solution?
/ Automatic start #7
That's as funny as all get-out. :ROFLMAO:
I like the spuing diesel MOX.
2023 JOHN DEERE 333G SKID STEER (A64277)
2023 JOHN DEERE...
2018 DODGE RAM 2500 (A65643)
2018 DODGE RAM...
International Harvester (IH) 130 Manure Spreader (A66408)
International...
2016 Ford Flex SUV (A64557)
2016 Ford Flex SUV...
2020 Komatsu PC210LC Hydraulic Excavator (A64553)
2020 Komatsu...
New/Unused Wolverine 84in Dozer Blade/Snow Pusher (A65583)
New/Unused...
