Automatic Gate Opener
/ Automatic Gate Opener
They make a locking pin so its not as easy to just disconnect it. I know nothing is IMPOSSIBLE but some are more difficult than others to remove. These days, an 18V battery-powered grinder is cheaper and easily accessible to thiefs.
/ Automatic Gate Opener #22
Don"t go making it impossible or difficult for you to disconnect.
Say you get a foot of snow on the ground and want to make sure everything swings freely so you don't mess up the opener, the weather won't likely be the same as when you install.
A regular lock works fine but a bolt rigged up to appear welded is a bigger obstacle to anyone that likely already has a set of bolt cutters.
/ Automatic Gate Opener #23
Should not need to do that. Mine has a switch you just flick and it disconnects the motor brakes and it swings free.
/ Automatic Gate Opener #24
Sooner or later im going to install an automatic opener on the gate i built. Its 14' and about 500#, but opens very smoothy. I dont want a piston opener. I plan on installing a pad mount unit also, but too many other expenses right now. \
/ Automatic Gate Opener #25
Some day ill get around to installing it.View attachment 306064
Neat gate! You do that yourself?
/ Automatic Gate Opener #27
Oops! Sometimes it pays to read the text, no just gawk at the pictures.
yup...built it a few years ago. Had to make and install a 1/4" thick 5" x5" post and have it powder coated white to match the vinyl fence and still be able to hold the gate up without a wheel or a torsion wire. The gate swings freely.
Got the forms built and in place. Now ready to mix concrete tomorrow for the pad. Got a buddy that might stop by to help for a while. Heres a shot of my gate and my progress. You can see "little mans" shovel that i got him. We used his other one in our flower beds, that was until i backed over it with the tractor and bent it in two.
/ Automatic Gate Opener #29
thanks for the pictures
/ Automatic Gate Opener #30
The pad will be at least 24"x28"x16"+ deep. Ive thought about mounting the keypad to that tree along side the drive, but im not sold on that yet.
We are required to have a KnoxLock on the outside for emergency personnel entrance. Ive heard stories where a house burned b/c a resident didnt pay their annual dues to the local fire district. The FD still came out to the fire (to keep it from burning the neighbor's house down.) I would think if you didnt follow code and get a permit and your house burned b/c the FD didnt put it out, your homeowners insurance might be a bit P.O.'d....
I don't know what soil type you have at your place but I would make the pad significantly deeper than 16". In fact I would drill a hole below frost line under it and use few rebars to anchor the pad to it.
My gate is light "farm gate" hinged on about 10-12" post that goes 5 feet in ground and the opener turned the post small angle with every opening or closing. I had to anchor the post to the next post to stop it.
Wish you success with your project.
Ladia
The gate posts are 5x5 and have been set 4' deep since 2006. The column footing is 12" deep and has been in place since 2008. The mfc recommended the 24x28x16 pad dimensions. I wanted to expand it 30x36 for added rigidity and an easier time placing the motor in the exact spot.
Finally got the opener installed. My wife bawked about the cost initially, but sometimes you just know deep down that she will like it. I havent heard a single complaint since the install. Plus we sleep just a bit more peacefully at night. I thought the solar panel was a bit large at 24"x24" but its necessary to charge the 24V system. I figured a strategically placed bush can all but make it disappear.
2015 Honda Accord Sedan (A61574)
2015 Honda Accord...
2022 EZ-GO ELITE...
REMINGTON ELECTRIC POLE SAW (A62613)
REMINGTON ELECTRIC...
2010 Dodge Grand Caravan Van (A61574)
2010 Dodge Grand...
2009 Toyota Camry Hybrid Sedan (A61574)
2009 Toyota Camry...
2012 Dodge Charger Sedan (A61574)
2012 Dodge Charger...
