Auto Coal bunker
/ Auto Coal bunker #1
Rgillard
Ireland
Fiat 82-94
Hi guys,
My Mam's friend recently told me of the trouble she has filling a bucket of coal from her bunker. She asked me was there some way in which i could make the coal fill up without her having to bend down. She also finds it hard to get the coal out when it is very full up.
I was considering trying to implement some kind of conveyor at the bottom of the bunker, raising the bottom of the bunker over the height of a bucket and sloping the sides of the bunker into the conveyor. I was also thinking if i put some kind of plate above the conveyor (8"-9") it would mean that the conveyor would fill from the side and reduce the weight of the coal pushing down on the belt.
Do you think this would work. I was going to run the belt with a motor. Any comments would be appreciated
/ Auto Coal bunker #2
Don't know of any coal being used in this part of the States for 60 years..so that's INTERESTING! But sorry..no first hand knowledge.Maybe add some paddles to the belt? Any chance of finding a section of grain auger laying about? Probably need a worm drive (rototiller comes to mind...but that would still have to be belted down).
/ Auto Coal bunker #3
What size are the chunks of coal?
Would placing a bucket under a sliding plate on the bunker work?
We had a coal furnace with a stocker on the farm. The stocker had a hopper feeding an auger going into the furnace. Driven with electric motor and activated by the thermostat.
Egon
/ Auto Coal bunker #4
Found this picture of a screw on a wood pellet stove...might give you some ideas.
/ Auto Coal bunker #5
A few years ago, a gentleman needed something similar to what you just described.
As I worked for a while with an airline company as a "ramp rat" which is a luggage handler, we used belt loaders constantly.
What we designed was much the same. It consisted of hard rubber rollers purchased from a boat trailer manufacturer, the larger rollers already have the "V" section molded in the center. Small motorcycle sprocket and chain on the end driver roller.
The project was designed to add all the stone, mortar and materials to a second story add on to his home. It moved all the stone to extend his fireplace, mortar, lumber and related materials. It worked quite well.
It is certainly feasible to build a scaled down version of something like this. Hope this helps, and good luck on your project.
Regards, Mark
/ Auto Coal bunker #6
Well I'm still young enough to remember helping my dad work on more than a few old coal furnaces that used augers to feed the coal to the cast iron fire pot. I would think if you were lucky enough to find one of those old relics (augers) that it would suit your purpose real well. They were pretty simple in the way they operated. Just keep all your body parts away from the screw when its rotating.
/ Auto Coal bunker #7
We used to have a coal stoker that had coal in it (shoveled it in from the coal bin about 10' away) and had an auger in the bottom that fed the coal into the bottom of the furnace. Then just had to keep removing the clinkers with some fancy tongs on a long handle and remove the ashes.
Pellet stoves and corn stoves operate that way now too, with the pellets or corn being pushed up from under the fire.
Not sure how close this relates to what is called a 'bunker' but maybe its close.
A search on "coal stoker" brings up a lot of hits.
/ Auto Coal bunker
The pieces of coal range from slightly bigger than a golf ball to about a piece 8"x4"x3". Thats a bit of a guesstimate. Would an auger not be harder to set up than a belt and would it transfer the material without getting jammed???A belt with paddles sounds like an easier method. Would the weight of the coal stop the belt from turning???
/ Auto Coal bunker
Here is a picture of the type of bunker im on about
/ Auto Coal bunker #10
Put That Bunker on a stand so the outlet is at a convienient height.
Should be easier than conveyer belt.
Egon
/ Auto Coal bunker #11
wow tiny, i was picturing something large enough to hold about 3 or 4 tons of coal
/ Auto Coal bunker #12
Sorry, as I pictured something completely different.........like a coal cellar, or a large area (room) full of coal and the need to load from floor level to waist high.
On the previous design; the more weight added to the belt the less slip one encountered.
Regards, Mark
/ Auto Coal bunker
Yeah I know its a **** little thing but she wants the coal to automatically feed from the door. I was going to raise it up off the floor and try install a little belt that feeds the coal out for the lazy so and so? do u guys still think it would work even though the effort making it is probably more than the effort to fill a hundred buckets?
/ Auto Coal bunker #15
Since this your Mam's friend...I am assuming that she is a little older at least than yourself...I am of the opinion that anything done for our elders will be considered when WE are that age...even if she is a so and so... /forums/images/graemlins/smirk.gif
2019 Allmand Night-Lite V-Series 7 kW S/A Towable Light Tower (A55973)
2019 Allmand...
1993 Baja 29ft. Boat w Tri-Axle Boat Trailer. (A59231)
1993 Baja 29ft...
ENCLOSED DRIVING SIMULATOR TRAILER (A58214)
ENCLOSED DRIVING...
2012 Ford E-350 Enclosed Service Van (A59230)
2012 Ford E-350...
5th Wheel Hitch (A59230)
5th Wheel Hitch...
UNUSED FUTURE 16" HYD AUGER (A52706)
UNUSED FUTURE 16"...
