atv/utv working machines picture thread
/ atv/utv working machines picture thread
Here is a "field" I used to mow. I used a Rhino and a Grizzly atv in subsequent years. Utilizing the atv cut more than a hour from the time it took.
/ atv/utv working machines picture thread #222
I'm curious what you folks who live in snowy places do for UTV tires. I've got Carnivores on mine and they're awful in snow. I've done winter group rides in WV and nobody seemed to do very well climbing snow covered hills.
I put R1 tires on ours:
And disconnected the sway bar for more articulation:
/ atv/utv working machines picture thread #223
How deep is the snow you are riding in?
/ atv/utv working machines picture thread #224
/ atv/utv working machines picture thread #225
Stock tires on the Honda (right) or the Tractor Supply replacement (left)
/ atv/utv working machines picture thread #226
Have you actually run the R1 tires in deep snow?
No, rarely get deep snow here.
I was not happy with R1 tires on an old tractor for plowing snow. I ended up needing good chains for it (studded "Euro-style" a.k.a. diamond pattern chains)
My only R1 tires in the snow pictures:
They didn't slip at all going up the steep hill to where I took the pictures:
/ atv/utv working machines picture thread #228
I wonder what the load capacity of those tires are? How well they handle several inches of snow means nothing to me! The current rear chevron tires on my Toro Workman have worn down significantly but finding a set to replace them would be a chore. The ones that came on it were a seldom seen optional set of solid rubber tires. They are heavy, don't help the rough ride and get worse traction than most inflated tires. The reason I like them? They handle just about any load i can put in the bed of the Toro without fail! Since the bed is rated for 2150 pounds, it takes a good tire to handle that weight!
David from jax
/ atv/utv working machines picture thread #229
If the snow is only a couple of inches, then ATV tires should be fine. In deeper snow there is no substitute for tracks.
/ atv/utv working machines picture thread #231
Carnivores love the mud, but they don't love the snow.
Found this across the road as we left camp which can be seen on the left. You can see on the supplies we move in and out in the bottom pic.
/ atv/utv working machines picture thread #237
Nice cart. Lots of clearance there.
/ atv/utv working machines picture thread #238
The dead ash on my dad's property are dropping daily. I keep the trail clear as well as all our trails.
/ atv/utv working machines picture thread #240
Old 6k gen set transport device to hook up to 6 gal. Pancake compressor to blow out my newly installed drip irrigation for the winter. I welded a cheap axle and tongue on the used and abused generator frame yrs ago makes it much easier instead of tryingvand manhandle and attempt to put on trailer or truck bed for short transport.on my unintentional wild life sanctuary.
Hot Pressure Washer S/A Trailer (A59228)
Hot Pressure...
2003 Pierce 75ft Ladder Fire Rescue Truck (A55852)
2003 Pierce 75ft...
UNUSED INDUSTRIAS AMERICA F10 TILT LAND LEVELER (A60430)
UNUSED INDUSTRIAS...
2016 Ford F-550 Altec AT233P 35ft Bucket Truck (A59230)
2016 Ford F-550...
UNUSED FUTURE...
UNUSED RAYTREE RMA42 HYD AUGER (A60432)
UNUSED RAYTREE...
