rswyan
Super Star Member
- Joined
- May 12, 2004
- Messages
- 13,391
- Location
- Northeast Ohio
- Tractor
- Kubota B2910, Cub Cadet Pro Z 154S, Simplicity 18 CFC, Cub Cadet 782
A couple of days ago the weather was looking pretty decent for the next 24 - 36 hours so I thought I would try and get my Roundup spraying done. I had sprayed a urea solution (46% nitrogen) on the lawn the day before and I hadn't bothered to clean out the tank afterwards, knowing that I would spray the next day if the weather looked good.
Before I started mixing the Roundup solution I decided that I would flush the tank, boom, and wand out with water. I pulled the tractor with sprayer attached around to the front of the garage and turned on the water and stuck the hose in the tank to fill it. As the tank was filling I turned on the pump, boom and wand to flush things out. After water started running out of the fill hole I cut the spigot off and just let the boom and wand run, while I sat there in a lawn chair reading the Roundup directions, periodically looking up to check the progress of emptying the tank. At some point I looked up and noticed that the tank was pretty much empty, the boom was no longer running but there was still a stream coming out of the wand. So I got up and shut off the pump, closed the drain valve and turned the spigot back on to fill the tank half way.
With the tank half full I decided to turn the pump on to adjust the nozzle on the wand before I had the tank filled with Roundup ......... nada ...... the pump is running but nothing is coming out. Tried the boom, wand, and bypass - all of them produced zip. It had been been working fine just a minute or two before ........
So I go call Fimco ..... I'm thinking it's the check valve again (my original pumps check valve had died last year and Fimco just replaced the whole pump) .... I want to confirm it's likely the check valve, which "Jim" (?) on the their tech support line says is a good candidate ..... and also offers to send out another check valve (freebie - even though technically I think I was over 1 year) I happily take him up on it (replacements are $20+) - it arrived today.
Over this last weekend I decided to take my original pump apart and have a look-see to check if I could see anything visually that might be amiss. I disassembled the pump - pretty easy - 6 bolts - and pulled it apart. No obvious tears or punctures in any of the rubber valves (there are about 6 or 7 of them) - but the valves and insides were coated with this white residue.
I tried cleaning it off with a toothbrush and some Dawn dishwashing soap in water. That really didn't touch it - the white residue reappeared after the parts dried. So then I decided to go a little more industrial-strength on it and got out my bottle of "Rubber Re-Nu". This is a solvent-based product that is used to "renew" rubber rollers on printers and copying machines when they get old and hard. It works very similar to lacquer thinner on rubber (which I ended up using as well) - it softens it up and gives it a new "tacky" surface. This worked much better and I was able to pretty much clean off all the white residue.
I put the pump back together but I still have to swap it out with the non-functional pump that is currently on the sprayer and test it to see if it works - probably won't get to that until Wednesday night or Thursday morning. Once I do, I'll post my results.
