atv question
   / atv question #1
sal64
Platinum Member
ny orange county
jd 2320 jd 990 jd950
HELLO ALL i have an old atv 1986 honda sx350 the atv runs good plenty of power put after i drive it a few times about 30min and shut it of it wount start becase the plug is fouled it has carbon on it not oil i clean the plug and it runs fine again this has been happening for a few yrs now but its getting worse also the oil is very milky any idea what is causing this?tu.
   / atv question #2
Milky oil is usually an indication of water in the oil. This can be either from a leak allowing water in from the atmosphere, or condensation. Condensation is usually the culprit if the machine is run for short periods and rarely run long enough to get the oil good and hot and boil off the water.
Sounds like the plug is fuel fouled. Running too rich either due to a mis-adjusted or worn carburetor or a plugged air filter.
   / atv question #3
Carboned up plug suggests the fuel mixture is too rich.
Maybe you're running it with the choke "on", which on a Honda is usually "up". If choke's NOT "on" maybe the richness is caused by plugged air filter, too much resistance acting like a 'choke" & sucking too much gas. You might take a look at the air filter. On a machine 30 years its possible that there is no air filter at all, the foam may have disintegrated and all sucked thru the engine :shocked: YIKES! I've had this on a 1997 Honda yours is 11 years older.
Don't run it with milky oil, change the oil. Don't fuss about oil types just get some clean oil in there. And take note if the new oil becomes milky.
   / atv question
tu for the responces. i do only run it a few minutes at a time.i think i will rebuild the carb and see it that helps.
KUBOTA SVL97-2 SKID STEER (A51242)
KUBOTA SVL97-2...
2013 Nissan Sentra (A50324)
2013 Nissan Sentra...
Cat TH407C Telehandler (A52128)
Cat TH407C...
2012 VOLVO A40F OFF ROAD DUMP (A51242)
2012 VOLVO A40F...
New Kivel 4200 lb. Skidloader Forks (A50774)
New Kivel 4200 lb...
2011 Chevrolet Colorado LT Pickup Truck (A50323)
2011 Chevrolet...
