ATV Dolly question
/ ATV Dolly question #1
RobA
Platinum Member
Chester County, SE PA
Kubota L5030 HST
tina said:
I've never used them, seems quite simple, jack it up and slid the dolly unneath.
I guess I was looking for something I could drive the ATV up on and then roll it around the barn. Didn't want to mess with a jack.
/ ATV Dolly question #4
How about a 4 X 8 sheet of plywood with casters on the corners and a small removable ramp kinda like a trailer with the fold up or removable ramp. You should have less $$ and it would be better and lots of things will fit a sheet of plywood to be moved around your shop.
Jim:)
/ ATV Dolly question #5
We use the skidoo dollies frequently. Lift the back end and kick the dolly under, then the skis. It helps to have two people and you need a smooth floor in the workshop. I have a dirt floor in the barn so I move the forks together so they just straddle the track, slip on the extensions(the forks are round bar, the extensions 8' of square tube) and pick up the sled from the rear. My ATV gets driven to its parking spot. I also have a stack of skids that I use for tires, the snow blower etc.
/ ATV Dolly question #6
You could get one of the ATV/motorcycle jacks and kill 2 birds with one stone. Use the jack when needed to work on the ATV and jack it up and roll it around in the shop to use as a dolly. Just don't buy one of the cheapo ones from Homier etc. like I did. Buy a better quality name brand one. Craftsman has one, Northern tool probably does too.
*Edit* Here's one from Northern that uses air to lift. There are some that use a hydraulic bottle jack.
/ ATV Dolly question #7
Doesn't your "ATV" have wheels on it? Duh. :D :D , sorry, couldn't resist.:eek:
I was waiting for someone to say that. Not sure why but it's a pain to roll around. Doesn't roll as easy as you think. It would be much easier to move with dolly wheels under it. And, since I'm trying to maximize space, a dolly would allow me to move sideways too.
/ ATV Dolly question #9
What about some of the little potted plant "coasters" used on porches to wheel around large plants? One under each wheel, probably cost $5 each. May take two people, don't know how hard it is to pick up a corner at a time, or as someone said, use a jack. Leverage is a good thing, stick a 2x4 or piece of pipe over a cinder block.
/ ATV Dolly question #10
I would be willing to try the plant coasters first. If it doesn't work then return them. I think that you couldn't build the 4 dollies for less than what Northern Tool is selling them for, especially with how much 16 casters are going to cost. Or you could order this ATV/motorcycle jack from Sears for $10 more. also can be used as a dolly.
Craftsman 34612 Motorcycle/ATV Jack at Sears.com
How about using the jack to lift the ATV then sliding the plant coasters underneath. Then you could use the jack for something else. May need another ATV to make the jack worthwhile. I would try that excuse on my wife.
New 1.5x27 Ratchet Strap (A65579)
New 1.5x27 Ratchet...
Bush Hog 285 3-Pt Rotary Cutting Mower (A66285)
Bush Hog 285 3-Pt...
2025 Kubota SVL75-3HFWCC High Flow Cab Track Loader - 70 hours
2025 Kubota...
2025 Hydraulic IRANCH Tilt Bucket Mini Excavator Attachment (A64553)
2025 Hydraulic...
2025 MACK GRANITE GR64F DUMP TRUCK (A63276)
2025 MACK GRANITE...
2022 EZ-GO ELITE...
