ATTN: B3030 Owners
/ ATTN: B3030 Owners
Thats a fair question. Kubota really does not sink money into the seat on many of their tractors. Its defentialy a product worthy of a nice seat!
/ ATTN: B3030 Owners #22
MessickFarmEqu said:
$750! You must have called a parts counter. The markup (From a dealer & Kubota) is much higher over the parts counter than it is though the wholegoods Dept. MSRP on that seat from wholegoods is $360. You'd probably have to be charged the UPS fee's as well.
Where in the wholegoods pricebook did you that price?
Thanks
Bill
/ ATTN: B3030 Owners #23
It's a tough balance between offering the best of everything and keeping the price reasonable.
/ ATTN: B3030 Owners #25
I shimmed the front six bolt of the seat suspension. That brought the front of the seat up 1-1/2", leveled the seat right out for me & made it more comfortable. Cheaper than buying a $300.00 seat and didn't have to mess with any wiring for the safety switches under the seat. Took 15 minutes to fix
/ ATTN: B3030 Owners #26
Could you post a picture of that shim job piperflyer. Thankx in advance, Scott.
/ ATTN: B3030 Owners #27
Kioti has upgraded their standard seats on the CK20/CK25/CK30 to a suspension seat. I imagine it is about the same as the on Neil is talking about as a retrofit seat costs about $650.
My CK20 is pre2005 so has the old style seat. Sure would like to upgrade but $650 is almost as tough to swallow as $750.:mad:
/ ATTN: B3030 Owners #28
Here is a picture of the seat shimmed, gained close 1-1/2" on the front end. I just used some nuts I had laying around that were bigger than the stud bolts already on the seat frame. I slipped them over the stud bolts that Kubota uses for the frame.
#1 you need four bolts over the studs
#2 you need two bolts on the front adjusting rail
#3 you need two bolts on the front of the seat frame mount
If I had some metal and a band saw I would of made a wedge out of the metal and mounted it under the seat frame in #3 from front to back.
Pull the seat off with the front pin removed, easier to work on
/ ATTN: B3030 Owners #29
Thanks for the photos, im going to try the shimming before i shell out hundreds of dollars for a new seat.
/ ATTN: B3030 Owners #30
The way it's shimmed now is temporary. When I get some time I'm going to make two metal wedges and install them under the seat frame. It will be more professional looking and I can cut the wedge to the seat height I want.
2025 PJ CC162 T/A 16FT EQUIPMENT TRAILER (A59914)
2025 PJ CC162 T/A...
Landhonor HPF-11-3000G, 48" Heavy Duty Forks (A62679)
Landhonor...
2021 Bobcat T76 (A64126)
2021 Bobcat T76...
2022 EZ-GO ELITE...
John Deere 1023E (A62177)
John Deere 1023E...
2022 Takeuchi TL12R2 (A64126)
2022 Takeuchi...
