AT&T Mobley through router quit working
/ AT&T Mobley through router quit working #1
kcflhrc
Kansas
2013 John Deere 3032E
So this morning I cant get the wifi to work through my ASUS router but I can connect directly to the Mobley and get internet. Do you think the router went bad or more seriously do you think AT&T turned off the USB capability? Link lights all look good on the router, have rebooted everything and still cant get out through the ASUS. Can remote into each device and everything looks fine.
HELP!
UPDATE Just started working again all by its self. I swear I tried everything
/ AT&T Mobley through router quit working #3
Self fixing problems are a blessing and a curse! :D
/ AT&T Mobley through router quit working #4
What it sounds like is that it timed out. When you direct connected and then reconnected to the router the timer started again.
/ AT&T Mobley through router quit working #5
Had same issue, router went bad. I replaced with a Trendnet.... Much more stable.
/ AT&T Mobley through router quit working #7
There has been talk of AT&T forcing the timeout setting back onto the Mobley with a recent update, but I haven't experienced it. I'm keeping my fingers crossed.
Rob
It wasn't a timeout. I don't believe. Before I did anything I connected to the Mobley and it was fine. Only when connected through the router it didn't work. I'm blaming it on the Russians
/ AT&T Mobley through router quit working #10
Rob
Have you looked at the version number on the "About" page?
Mine updated a long time ago, is now set to 30 minutes, but it never times out.
/ AT&T Mobley through router quit working #14
No, I haven't. Because I haven't had any problems. I was just relating info about what others have been claiming from other Mobley threads.
Rob
Rockport Mobile Command Center (A59230)
Rockport Mobile...
2014 Bobcat T650 (A60462)
2014 Bobcat T650...
UNUSED KJ K2545W-46'X25' METAL GARAGE (A60432)
UNUSED KJ...
EZ-GO Electric Golf Cart (A60462)
EZ-GO Electric...
3ft Metal 5-Point Star (A59231)
3ft Metal 5-Point...
UNUSED SET OF FUTURE 13', 200AMP JUMPER CABLES (A60430)
UNUSED SET OF...
