arps80 hackhoe big thum
/ arps80 hackhoe big thum #1
Army grunt
Platinum Member
Georga
TC 30 Newholland
I have just spent a few days digging with a very well used back hoe ,I see the need for having a big thum for it i have a hy. cylinder from a fisher plow. would this be ok ? also i was looking in northern tool for the right valve any idea witch one i need?
Army Grunt
/ arps80 hackhoe big thum #2
All the fisher plows i've had, had single acting hydraulic cylinders. I'd look at that first because i think you'll need to find a different cylinder.
Ok, I will have a spair one from replacing the swing cilinder. Ill replace the ceals (if i can find a soarse for rebuild kit)
Still in-da-game :)
Army Grunt
/ arps80 hackhoe big thum #4
its alot easier and cheaper to make a ridgid thumb that you can just adjust with a pin, and fold against the boom when not in use. you will have a grand into hoses and a valve likely by the time your done. unless your doing alot of work with the thumb a non hydraulic one works just fine.
JOHN DEERE 4450 TRACTOR (A64278)
JOHN DEERE 4450...
1987 PETERBILT 377 T/A DAY CAB ROAD TRACTOR (A64278)
1987 PETERBILT 377...
2007 Mack CTP713 Wet Kit T/A Day Cab Truck Tractor (A64194)
2007 Mack CTP713...
3148 (A63117)
3148 (A63117)
1536 (A65054)
1536 (A65054)
20 Ton Air/Manual Hydraulic Bottle Jack (A64556)
20 Ton Air/Manual...
