Are canopies safe?
/ Are canopies safe? #11
My canopy has two 4x4 steel square tubes under my canopy running the length of the UNDERside of the canopy to the front of the tractor. Plenty of support and protection.
4x4 steel tubs... that sounds pretty heavy duty! The tubes run all the way to the front of the tractor? Do you have a cage around you?
My canopy has angle iron bracing that runs the length of the canopy. I don't know how much strength and support it would give on a 360 degree rollover, like down an embankment.
/ Are canopies safe? #13
My canopy is 1.5 x 1.5 square tube rails with angle iron supports ( ford / nh install ).
Either way, whatever force the canopy is able to absorb... your body won't have to.
Soundguy
2026 tilt trailer (A56859)
2026 tilt trailer...
2011 MULTIQUIP LIGHT PLANT/ FUEL TANK TRAILER (A58216)
2011 MULTIQUIP...
2015 TEXAS PRIDE TRAILER  30 FLATBED GOOSENECK TRAILER (A58214)
2015 TEXAS PRIDE...
CHALLENGER VACUUM PUMP (A60736)
CHALLENGER VACUUM...
Unused 2025 HD Trailer Solutions EQ17.5 20ft. 8 Ton T/A Equipment Trailer (A59230)
Unused 2025 HD...
1986 Eager Beaver B9D0W 20ft. 11 Ton Tri Axle Dovetail Equipment Trailer (A59230)
1986 Eager Beaver...
