Are Bob Tech and SSQA the same?
/ Are Bob Tech and SSQA the same? #1
manac
CT
NH WM 70
New to the SSQA world. Looking at a grapple bucket that came off a Bobcat 943 for my NH WM 70.
Owner says it’s Bob Tech but that it won’t fit my SSQA. I‘ve seen a bit on the net saying that Bobcat developed the Bob Tech standard and the it was adopted by other manufacturers and sold as SSQA.
Thanks for your help.
/ Are Bob Tech and SSQA the same? #2
Thanks, I had read that first link. It was the only thing I had found so I wanted to make sure.
/ Are Bob Tech and SSQA the same? #4
Just measure across the top of the quick attach plate, there was a old bobcat standard that is about 39 in wide, anything newer should be around 45 in wide which is probably what it is, but I would double check.
Aaron Z
/ Are Bob Tech and SSQA the same? #5
Some dimensions:
40ft High Cube Shipping Container (A65583)
40ft High Cube...
1994 New Holland 580 Square Baler (A63688)
1994 New Holland...
2022 EZ-GO ELITE...
2015 FORD F-150 LARIAT CREW CAB TRUCK (A59823)
2015 FORD F-150...
Case International 21' Disk Harrow (A64127)
Case International...
2017 Mack Semi (A64047)
2017 Mack Semi...
