Anyone use this "quick connect"?
/ Anyone use this "quick connect"? #1
Limecuda
S/E Texas
Anyone tried this quick connect system? It also has a gauge rod to keep the arms adjusted to the implement. It is about a 1/4 of the cost of the one advertised here.
/ Anyone use this "quick connect"? #2
who makes it?
larrry
I do not know. They are on ebay.
/ Anyone use this "quick connect"? #4
There is also another one on ebay that is about 1/2 the price of Pats. Both of these have shortcomings such as using cotter pins and smaller clip pins, but for the price they may just work fine (I don't have either but am looking at them as well).
I really don't understand (and am not complaining) how the PEC system costs just as much or more than a complete QuickAttach frame system. Less metal, lighter, smaller, etc.....yet more expensive?
Welcome to CARTER AND SON'S TOOL AND DIE
/ Anyone use this "quick connect"? #5
I bought Pat's back before he had competition and now that there are cheaper alternatives I'd do it over again. Pat's is a bit pricey because of how well he thought out the attachment to the side arms, most of the rest look like they'd be fine with lightweight implements but I'd be worried about damage or breakage with anything heavy. I'm guessing a lot of testing went into the design, many of the others you seem to be paying for raw materials and amortized use of a milling machine but not any real world experience (or import duties or patent rights - but that's another story...). I also like the spring locks better than the simple retaining pins I've seen - I've got a finicky chipper that would keep slipping out without the spring locks. Besides, I always like to reward the first guy able to crack the code and bring out a marketable product, and being able to buy it through the TBN store hopefully supported them a bit :)
As to why Pat's is more expensive than some of the iMatch-like system, it's hard not to make a big chunk of metal with three attachment points stable. Add to that a standard describing how to build it and mass-market production rates and you've got a lot of economies working for you. I'm afraid the days of melting down the raw materials to gauge the price of a product only exist in regions of the world where wages are cheap enough to allow it :(
So for me Pat's is the right choice from an engineering, personal and (for some competition) political perspective. Since the worst Pat's failures I've had were not buying the stabilizer bar when I bought it (my own darn fault and since rectified :)) and losing some of the nuts (again, I didn't tighten them enough - the replacements I got at Lowes are holding fine) I'm very happy with my choice. Hope you find a suitable solution that works for you, I know my priorities may be different than yours. :)
/ Anyone use this "quick connect"? #6
I have been watching both of the 'alternative' ez hitch/quick connects on ebay for a few weeks now.. I am pretty much leaning toward the $54 set (original post) - especially since it includes the spreader bar..
Someone in another post mentioned that he could not use the one shown above because his tiller would not allow the use of the 'stops'..
Brian
/ Anyone use this "quick connect"? #7
Buy those! You'll be supporting a neighbor of mine. Not sure how many he's sold, but he sure has moved up in the "obvious wealth" catagory!
/ Anyone use this "quick connect"? #8
JDBower - All good points, and I understand the economies of scale / China manufacturing and what not......I was looking at the pricing from a competitive market perspective - i.e. the "local" rep selling Pat's wanted 230 each plus tax that would leave me at about $245 for a set. From a design/utilization/marketability perspective, if the pricing is comparable then I am left with a coin toss decision on whether to buy a iMatch-like system or a PEC.
If the PEC was competitively priced at about $175 (delivered) then the iMatch wouldn't even be a consideration and I'd already own one and be sendiing all my tractor friends to see Pat!
/ Anyone use this "quick connect"? #9
Ah, I see the issue. In my mind Pat doesn't compete with the iMatch-type systems - if all my equipment was iMatch compatible I'd just use that since I wouldn't need to get off the tractor for the toplink (only the PTO which may not always be needed). The pesky chipper I mentioned can't easily be modified to be iMatch compatible so it's the main reason my iMatch lies idle most of the time (it's easier for me to use Pat's system on my tiller than it is to mount the iMatch just for that). If I get a rotary cutter and box blade that are iMatch-ready I may only install Pat's when I need the chipper and the tables turned, but for now I've got a big, green U-shaped paperweight :). I do agree that if Pat wants to compete with iMatch rather than just fill the gap where iMatch doesn't work pricing is a concern, maybe once he's paid off his NRE or manages to increase production he'll end up doing that.
/ Anyone use this "quick connect"? #10
So from your perspective the leverage for PEC is the universal application versus others being customized............thanks for the heads up - because I just went into the JD website and once again "read" the details a little closer. Apparently you need to add custom pins or collars to every attachment to match up with their iMatch. I thought it was like a Harbor Freight Quick Attach device that simply converted the lower lift arms from knuckle-balls into hooks.
Now the comparison pricing starts adding up against the JD system, and the fact that I don't really have all JD attachments makes it even worse. Ok - I'm converted..........now to decide between those mentioned above and PEC.........hmmmmmmmmmmmm
/ Anyone use this "quick connect"? #11
Brian
That was me. The "stops" stick up too much to allow use with our tiller and backhoe, so I ordered a set off of ebay that are almost exactly the same, but don't have the extended stops. They've been awesome so far. I paid about $55 a set, shipped to my house. For a fourth of the price, I don't mind dropping a grade 8 bolt and keeper pin in the hole, especially since I have to get off to hook up the top link and PTO anyway.
/ Anyone use this "quick connect"? #12
I just installed a very similar quick attach system on my tractor. Slight difference in that mine doesn't have the big metal riser but otherwise the system looks identical. I'll have to look up the manufacturer but I think it was EZ Link or something like that.
I had trouble installing mine only because the x!@#$%^ manufacturer did not bother including a couple of simple toplink pins in the package which are required. As a result I had to make a separate trip and then when I installed them the toplink pins did not match the washers provided so the implement fell off. Two trips later they were finally installed properly. What should have taken 2 minutes to install ended up taking two extra trips to a tractor supply store due to poor directions/failure to include a couple of cheap pins/washers though.
I am not exactly enthusiastic about these quick attach devices but it is mostly because of the installation hassle. It actually only should take one minute to install them if the correct parts are provided in the package. They do work though in my case there is no spacer bar holding the 3pt arms apart so I need to watch that as I back up under the implement. They do avoid the usual bashing and kicking necessary to line up pins with the 3pt and they provide a secure attachment so in that sense they are fine.
/ Anyone use this "quick connect"? #13
I bought these exact hitches off ebay. I have had wonderful luck with mine all the parts were included and the spreader bar was a nice option too. I really like them so far. Very Very heavy materials....I ordered them and had them at my door in two days. O just one word of advice....Dont gorget to take the spreader bar off after you hook your bush hog up....hahah....see where this is going....I forgot and raised the hog off the ground.....bent thepeice that slides in and out of the spreader bar. Hope this helps in your decision....
/ Anyone use this "quick connect"? #14
I have this quick disconnect for my Cat II Kama 554. It works even on a post hole digger, but there is a lot of play in the mount of the disconnect on the lift arms. So there is a lot of wear on the quick disconnect.
/ Anyone use this "quick connect"? #15
Of the two quick connects (other than Pat's) shown in this thread one appears to extend the lift arms, while the other connect coupling appears to sit above the lift arms. Does anyone have an opinion on which style would be preferable, and why?
It would seem to me that the one from Carter (the one that has the connect above the lift arm) might not cause the same concern about the PTO shaft length that the other might.
/ Anyone use this "quick connect"? #16
kengreen said:
I .... So there is a lot of wear on the quick disconnect.
I too ordered have received mind. To replace the pins and bolts that makes up the quick disconnect is a minimal cost compared to the time spent having to change implements.
/ Anyone use this "quick connect"? #17
kengreen said:
.....but there is a lot of play in the mount of the disconnect on the lift arms. So there is a lot of wear on the quick disconnect.
So how did you eliminate the excess play in the lift arm connections?
/ Anyone use this "quick connect"? #18
I just bought the Carters version that sits on top of the lift arms. My thought was that this totally avoids the need for a longer top link or PTO shaft of the other versions - which it does without any problems in this area.
My only problem so far is excess play in the hitch attachment to lift arms previously mentioned here.......and don't forget that because of the extra height you need to make sure your attachments are not sunk too far into the ground or the lift arms/hitches will be too high to make a connection.
/ Anyone use this "quick connect"? #19
Just how many of you have had to add a PTO extension when you have used Pats (or a similar knock off)?? I am especially interested in someone with a JD 2320.
just curious and planning ahead..
Brian
/ Anyone use this "quick connect"? #20
I have a Kioti CK20 and did not need an extension.
2011 CLARK OIL FIELD FLOAT (A65643)
2011 CLARK OIL...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
1994 Geo Tracker, 5spd, Soft Top (A62679)
1994 Geo Tracker...
2020 WESTERN STAR  4900 TRI-AXLE (A65643)
2020 WESTERN STAR...
New/Unused CFG Industrial H15R Mini Excavator (A65579)
New/Unused CFG...
2006 Chevrolet C5500 Service Truck, VIN # 1GBE5E3256F423684 (A65563)
2006 Chevrolet...
