Anyone use Sch 80 PVC for air lines?
   / Anyone use Sch 80 PVC for air lines? #11
Agree. PVC gets more and more brittle, especially with sunlight.
A metal pipe will bend if you hit it by mistake. Old PVC will shatter.
Unless you’re really cash strapped, go for the correct material
How much is your eyesight worth? If you don’t have the cash just drag an airline from the compressor.
   / Anyone use Sch 80 PVC for air lines? #12
There is a HDPE tube with an aluminum ply that is intended for air line use. It is similar to PEX, but uses compression type fittings. Brand names would be Maxline or RapidAire.
Much better choice than PVC.
   / Anyone use Sch 80 PVC for air lines? #14
Need to plumb out my shop in the not too distant future. Was thinking about using Sch 80 PVC. I have heard of many people using it without issues.
Anyone out in TVN land using this in their shop?
When I built my shop in '83, I plumbed air around the inside with 1" Sch 80 pipe. At the time, I was the house carrier at the local plastic pipe company, so I got about 120 feet of it (6 20 footers) for free. Over the years, I've had two glue joints fail, and one minor leak at a joint. Other than that, it's been great.
Prepping the joint surfaces, using plenty of glue and allowing the joint to cure for a day or so before use is recommended.
   / Anyone use Sch 80 PVC for air lines? #15
I would use the correct line. When I plumbed mine I went to a local supply house and got everything I needed, line, compression fittings, etc. That was 30 years ago & never a problem.
175 psi 2 stage compressor.
Each thing has it's own purpose and I always go with that. Only thing I would change is compressor soundproofed.
2013 SHOP BUILT FLARE STACK (A53843)
2013 SHOP BUILT...
2006 FREIGHTLINER CL120 DAY CAB (A53426)
2006 FREIGHTLINER...
2014 Electric Cart (A53424)
2014 Electric Cart...
1982 LeeBoy Motor Grader (A55302)
1982 LeeBoy Motor...
(INOP) 2016 AUTOCAR EXPEDITOR GARBAGE TRUCK (A54756)
(INOP) 2016...
CAT EXCAVATOR BUCKET (A55745)
CAT EXCAVATOR...
