Anyone use Sch 80 PVC for air lines?
   / Anyone use Sch 80 PVC for air lines? #1
part-time-Farmer-NC
Kioti DK45Se
Need to plumb out my shop in the not too distant future. Was thinking about using Sch 80 PVC. I have heard of many people using it without issues.
Anyone out in TVN land using this in their shop?
   / Anyone use Sch 80 PVC for air lines? #2
Here is some info from Rapidair Products on materials for compressed air piping. PVC is NOT recommended.
   / Anyone use Sch 80 PVC for air lines? #3
We had pvc run originally in the shop at work. The issue we ran i to was the joints where it was glued would fail after a couple years.
After I fixed one leak, another would show up.
   / Anyone use Sch 80 PVC for air lines? #4
Pvc is affected by temps, and can violently explode under pressure. Mine is 3/4” copper piped
   / Anyone use Sch 80 PVC for air lines? #5
I have 3/4" PVC Sch 40 air lines in my shop and have had them for over 15 years with no issues. When I installed them I sanded the connections prior to gluing together.
My Compressor is set at 175 psi.
   / Anyone use Sch 80 PVC for air lines? #6
The working pressure of pvc is well above the compressor pressure. It works fine until it doesn’t. PVC can violently explode especially when it’s old and brittle. I’d use a different pipe.
   / Anyone use Sch 80 PVC for air lines? #7
Agree. PVC gets more and more brittle, especially with sunlight.
A metal pipe will bend if you hit it by mistake. Old PVC will shatter.
Unless you’re really cash strapped, go for the correct material
   / Anyone use Sch 80 PVC for air lines? #8
I have used Schl 40 3/4 and 1 inch PVC for air lines for years. The last shop had them up for 18 years before I took them down when we moved last year. The buyer didn't want them left, so I threw them away and put new lines in my new shop.
I made sure I used a good primer and a good glue when putting them together. I never had a coupling fail doing that.
2018 CHEVROLET SILVERADO CREW CAB TRUCK (A52706)
2018 CHEVROLET...
BOAT MOTOR TRAILER (A53424)
BOAT MOTOR TRAILER...
2015 Chevrolet Silverado 2500 HD Crew Cab Pickup Truck (A53422)
2015 Chevrolet...
2023 Ford F-150 4x4 Ext. Cab Pickup Truck (A55852)
2023 Ford F-150...
JOHN DEERE 410L BACKHOE (A52706)
JOHN DEERE 410L...
Gooseneck Livestock Stock Trailer - Tandem Axle Ranch Hauler - Selling Absolute, No Reserve (A55301)
Gooseneck...
