Anyone use Sch 80 PVC for air lines?
   / Anyone use Sch 80 PVC for air lines? #1
part-time-Farmer-NC
Kioti DK45Se
Need to plumb out my shop in the not too distant future. Was thinking about using Sch 80 PVC. I have heard of many people using it without issues.
Anyone out in TVN land using this in their shop?
   / Anyone use Sch 80 PVC for air lines? #2
Here is some info from Rapidair Products on materials for compressed air piping. PVC is NOT recommended.
   / Anyone use Sch 80 PVC for air lines? #3
We had pvc run originally in the shop at work. The issue we ran i to was the joints where it was glued would fail after a couple years.
After I fixed one leak, another would show up.
   / Anyone use Sch 80 PVC for air lines? #4
Pvc is affected by temps, and can violently explode under pressure. Mine is 3/4” copper piped
   / Anyone use Sch 80 PVC for air lines? #5
I have 3/4" PVC Sch 40 air lines in my shop and have had them for over 15 years with no issues. When I installed them I sanded the connections prior to gluing together.
My Compressor is set at 175 psi.
   / Anyone use Sch 80 PVC for air lines? #6
The working pressure of pvc is well above the compressor pressure. It works fine until it doesn’t. PVC can violently explode especially when it’s old and brittle. I’d use a different pipe.
   / Anyone use Sch 80 PVC for air lines? #7
Agree. PVC gets more and more brittle, especially with sunlight.
A metal pipe will bend if you hit it by mistake. Old PVC will shatter.
Unless you’re really cash strapped, go for the correct material
   / Anyone use Sch 80 PVC for air lines? #8
I have used Schl 40 3/4 and 1 inch PVC for air lines for years. The last shop had them up for 18 years before I took them down when we moved last year. The buyer didn't want them left, so I threw them away and put new lines in my new shop.
I made sure I used a good primer and a good glue when putting them together. I never had a coupling fail doing that.
TAKEUCHI TL150 SKID STEER (A51242)
TAKEUCHI TL150...
2008 BIG TEX 16 T/A TRASH TRAILER (A55745)
2008 BIG TEX 16...
Portable Restroom (A54865)
Portable Restroom...
2019 VOLVO VNR TANDEM AXLE MID ROOF TRUCK (A56129)
2019 VOLVO VNR...
2025 MAMMOTH SB-2 2025 SAND BOX TRAILER (A56129)
2025 MAMMOTH SB-2...
BRAKE DRUM HANDLER (A55745)
BRAKE DRUM HANDLER...
