Anyone use Rotella T6 Full Synthetic in their LS
   / Anyone use Rotella T6 Full Synthetic in their LS #71
How often should T6 be changed, relative to other oils, either conventional or fully synthetic?
Will I do not have an LS T6 is the oil that we stock of most everything we change around the place since it is the best all around gas/diesel oil that I have ever used. I change mainly on looks since we do not put a lot of hours.
I did the first oil change on the 1980 3600 Ford that has had Rotella 15W-40 per the owner of the last 32 years. I found 2 gallon jugs of T6 that I bought 27 March 2012 and it still looked like new. :)
   / Anyone use Rotella T6 Full Synthetic in their LS #72
I say, it is your tractor run what you want but why would you not run 5w? Unless you are in a southern climate I would be running 5w if there is a chance your starting your tractor in the winter; especially if you are in a northern state.
So what is the difference weight wise of a Rotella 5W-40 vs 15W-40 at 180F degrees?
   / Anyone use Rotella T6 Full Synthetic in their LS #73
It should be the same. The 5W-40 should pour faster when cold than 15W-40.
   / Anyone use Rotella T6 Full Synthetic in their LS #74
Just change your oil at factory recommended schedule
At the cost of T6 and amount of oil used in these tractors just doesn't warrant extended oil changes..
   / Anyone use Rotella T6 Full Synthetic in their LS #75
I called LS (would suggest you do the same) T6 full synthetic 5W40 is just fine , the 5w40 will help in cold weather starting, this is why I use it in all my equipment..
   / Anyone use Rotella T6 Full Synthetic in their LS #76
Just picked up a rebate coupon at TSC for Rotella T6 or T5
   / Anyone use Rotella T6 Full Synthetic in their LS #77
In Astoria, Oregon at O'Reilly's Auto parts Rotella T6 is on sale for $19.99/gal! Cheapest I've found in a long time.
Rob
   / Anyone use Rotella T6 Full Synthetic in their LS #78
Thanks for the tip,
I'll buy some today!
2020 Bobcat T595 (A57148)
2020 Bobcat T595...
2023 PJ Trailer 1D192 14ft. 5 Ton T/A Dump Trailer (A55973)
2023 PJ Trailer...
Miller Bobcat Welder/Generator AC/DC Welder, 1 Phase & 3 Phase Generator, S/N M0321574R, Kohler Gas (A59076)
Miller Bobcat...
Brock 36'x17' Flat Bottom Grain Storage Tank (A57148)
Brock 36'x17' Flat...
2017 Mercedes Benz GLA SUV (A56859)
2017 Mercedes Benz...
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
