Anyone use Rotella T6 Full Synthetic in their LS
   / Anyone use Rotella T6 Full Synthetic in their LS #71
How often should T6 be changed, relative to other oils, either conventional or fully synthetic?
Will I do not have an LS T6 is the oil that we stock of most everything we change around the place since it is the best all around gas/diesel oil that I have ever used. I change mainly on looks since we do not put a lot of hours.
I did the first oil change on the 1980 3600 Ford that has had Rotella 15W-40 per the owner of the last 32 years. I found 2 gallon jugs of T6 that I bought 27 March 2012 and it still looked like new. :)
   / Anyone use Rotella T6 Full Synthetic in their LS #72
I say, it is your tractor run what you want but why would you not run 5w? Unless you are in a southern climate I would be running 5w if there is a chance your starting your tractor in the winter; especially if you are in a northern state.
So what is the difference weight wise of a Rotella 5W-40 vs 15W-40 at 180F degrees?
   / Anyone use Rotella T6 Full Synthetic in their LS #73
It should be the same. The 5W-40 should pour faster when cold than 15W-40.
   / Anyone use Rotella T6 Full Synthetic in their LS #74
Just change your oil at factory recommended schedule
At the cost of T6 and amount of oil used in these tractors just doesn't warrant extended oil changes..
   / Anyone use Rotella T6 Full Synthetic in their LS #75
I called LS (would suggest you do the same) T6 full synthetic 5W40 is just fine , the 5w40 will help in cold weather starting, this is why I use it in all my equipment..
   / Anyone use Rotella T6 Full Synthetic in their LS #76
Just picked up a rebate coupon at TSC for Rotella T6 or T5
   / Anyone use Rotella T6 Full Synthetic in their LS #77
In Astoria, Oregon at O'Reilly's Auto parts Rotella T6 is on sale for $19.99/gal! Cheapest I've found in a long time.
Rob
   / Anyone use Rotella T6 Full Synthetic in their LS #78
Thanks for the tip,
I'll buy some today!
2008 FORD F-650 SUPER DUTY (A58214)
2008 FORD F-650...
2013 RAM 3500 FLATBED (A58214)
2013 RAM 3500...
2025 YOU-380 Mini Skid Steer Loader (New/Unused) Includes Bucket and accepts multiple attachments (A59225)
2025 YOU-380 Mini...
Skid Steer Concrete Mixing Bucket (New/Unused) (A59225)
Skid Steer...
1991 TRAILMASTER CRUDE TRAILER (A58214)
1991 TRAILMASTER...
2012 TOP HAT TRAILER GOOSENECK FLATBED TRAILER (A58214)
2012 TOP HAT...
