anyone use Bailey Hyd. $49 2.5x20 cylinder?
   / anyone use Bailey Hyd. $49 2.5x20 cylinder? #2
Depends on use, better for pull stroke than push stroke since the rod is small for the length. I would pass if its failing while in use might harm someone.
Steve
   / anyone use Bailey Hyd. $49 2.5x20 cylinder? #3
I can't comment on the cylinder but I have been ordering from Bailey for my business for 5 years and am very happy with their products and service.
   / anyone use Bailey Hyd. $49 2.5x20 cylinder? #4
that would be virtually every product we use out on a farm. :rolleyes:
FYI if i did my math right it should be ~12K push 9K pull
   / anyone use Bailey Hyd. $49 2.5x20 cylinder? #5
Good point! It made me go back and look at the specs. 1 1/8in rod diameter doesn't sound too wimpy for a 20" stroke... Does it????
   / anyone use Bailey Hyd. $49 2.5x20 cylinder? #6
$49 sounds cheap. Shippings costs????
   / anyone use Bailey Hyd. $49 2.5x20 cylinder? #7
When you consider the pin to pin distance it is closer to 50 inches extended. You have to consider the extended length since both ends are able to swivel.
A good cylinder rod such as Enduro would cost over 50 bucks itself.
   / anyone use Bailey Hyd. $49 2.5x20 cylinder? #8
If everything you have on your farm is dangerous and life theatening why would anyone want your advise.:D
So what is your point? All cylinders can push harder than they can pull.
Steve
2004 FORD F-650 SUPER DUTY DUMP TRUCK (A51406)
2004 FORD F-650...
SULLAIR 185 PORTABLE AIR COMPRESSOR (A51406)
SULLAIR 185...
PNEUMATIC GREASE UNIT (A53843)
PNEUMATIC GREASE...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50323)
BW RVB3405...
2008 KZ Sportsman Police Bunk 5th Wheel Tri-Axle Travel Trailer (A51694)
2008 KZ Sportsman...
