anyone use Bailey Hyd. $49 2.5x20 cylinder?
   / anyone use Bailey Hyd. $49 2.5x20 cylinder? #2
Depends on use, better for pull stroke than push stroke since the rod is small for the length. I would pass if its failing while in use might harm someone.
Steve
   / anyone use Bailey Hyd. $49 2.5x20 cylinder? #3
I can't comment on the cylinder but I have been ordering from Bailey for my business for 5 years and am very happy with their products and service.
   / anyone use Bailey Hyd. $49 2.5x20 cylinder? #4
that would be virtually every product we use out on a farm. :rolleyes:
FYI if i did my math right it should be ~12K push 9K pull
   / anyone use Bailey Hyd. $49 2.5x20 cylinder? #5
Good point! It made me go back and look at the specs. 1 1/8in rod diameter doesn't sound too wimpy for a 20" stroke... Does it????
   / anyone use Bailey Hyd. $49 2.5x20 cylinder? #6
$49 sounds cheap. Shippings costs????
   / anyone use Bailey Hyd. $49 2.5x20 cylinder? #7
When you consider the pin to pin distance it is closer to 50 inches extended. You have to consider the extended length since both ends are able to swivel.
A good cylinder rod such as Enduro would cost over 50 bucks itself.
   / anyone use Bailey Hyd. $49 2.5x20 cylinder? #8
If everything you have on your farm is dangerous and life theatening why would anyone want your advise.:D
So what is your point? All cylinders can push harder than they can pull.
Steve
New Holland T2420 (A53317)
New Holland T2420...
7ft Titan Box Blade (A57453)
7ft Titan Box...
40ft High Cube Shipping Container (A57453)
40ft High Cube...
2017 John Deere 6105E (A57148)
2017 John Deere...
2016 GENIE Z-80/60 TELESCOPIC BOOM LIFT (A52709)
2016 GENIE Z-80/60...
2012 RAM 5500 (A58214)
