anyone use Bailey Hyd. $49 2.5x20 cylinder?
   / anyone use Bailey Hyd. $49 2.5x20 cylinder? #2
Depends on use, better for pull stroke than push stroke since the rod is small for the length. I would pass if its failing while in use might harm someone.
Steve
   / anyone use Bailey Hyd. $49 2.5x20 cylinder? #3
I can't comment on the cylinder but I have been ordering from Bailey for my business for 5 years and am very happy with their products and service.
   / anyone use Bailey Hyd. $49 2.5x20 cylinder? #4
that would be virtually every product we use out on a farm. :rolleyes:
FYI if i did my math right it should be ~12K push 9K pull
   / anyone use Bailey Hyd. $49 2.5x20 cylinder? #5
Good point! It made me go back and look at the specs. 1 1/8in rod diameter doesn't sound too wimpy for a 20" stroke... Does it????
   / anyone use Bailey Hyd. $49 2.5x20 cylinder? #6
$49 sounds cheap. Shippings costs????
   / anyone use Bailey Hyd. $49 2.5x20 cylinder? #7
When you consider the pin to pin distance it is closer to 50 inches extended. You have to consider the extended length since both ends are able to swivel.
A good cylinder rod such as Enduro would cost over 50 bucks itself.
   / anyone use Bailey Hyd. $49 2.5x20 cylinder? #8
If everything you have on your farm is dangerous and life theatening why would anyone want your advise.:D
So what is your point? All cylinders can push harder than they can pull.
Steve
Mini Skid-Steer Hydraulic Root Rake Grapple (New/Unused) (A59225)
Mini Skid-Steer...
2025 GIYI GY-SZYMJ Hydraulic Stump Grinder Mini Skid Steer Attachment (A56857)
2025 GIYI GY-SZYMJ...
3650 (A47477)
3650 (A47477)
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
SHOPMADE MANIFOLD TRAILER (A58214)
SHOPMADE MANIFOLD...
2013 International DuraStar 4300 Box Truck, VIN # 3HAMMAAL1DL085200 (A57453)
2013 International...
