anyone use Bailey Hyd. $49 2.5x20 cylinder?
   / anyone use Bailey Hyd. $49 2.5x20 cylinder? #2
Depends on use, better for pull stroke than push stroke since the rod is small for the length. I would pass if its failing while in use might harm someone.
Steve
   / anyone use Bailey Hyd. $49 2.5x20 cylinder? #3
I can't comment on the cylinder but I have been ordering from Bailey for my business for 5 years and am very happy with their products and service.
   / anyone use Bailey Hyd. $49 2.5x20 cylinder? #4
that would be virtually every product we use out on a farm. :rolleyes:
FYI if i did my math right it should be ~12K push 9K pull
   / anyone use Bailey Hyd. $49 2.5x20 cylinder? #5
Good point! It made me go back and look at the specs. 1 1/8in rod diameter doesn't sound too wimpy for a 20" stroke... Does it????
   / anyone use Bailey Hyd. $49 2.5x20 cylinder? #6
$49 sounds cheap. Shippings costs????
   / anyone use Bailey Hyd. $49 2.5x20 cylinder? #7
When you consider the pin to pin distance it is closer to 50 inches extended. You have to consider the extended length since both ends are able to swivel.
A good cylinder rod such as Enduro would cost over 50 bucks itself.
   / anyone use Bailey Hyd. $49 2.5x20 cylinder? #8
If everything you have on your farm is dangerous and life theatening why would anyone want your advise.:D
So what is your point? All cylinders can push harder than they can pull.
Steve
(INOP) 2019 KOMATSU D61PX-24 CRAWLER DOZER (A52705)
(INOP) 2019...
1742 (A58374)
1742 (A58374)
2018 John Deere 2025R Tractor - 647 Hours (A56435)
2018 John Deere...
2018 Chevy Silverado 1500 4X4 (A56435)
2018 Chevy...
LOT: (3) Shelves of Parts, Filters, Oil, Antifreeze (CONTENTS ONLY - ALL APPEAR TO BE UNOPENED) (A59076)
LOT: (3) Shelves...
2021 CTS HRD 37LW 34 Ton T/A End Dump Trailer (A55973)
2021 CTS HRD 37LW...
