Anyone know which of my 25 pto speeds is the 540?
   / Anyone know which of my 25 pto speeds is the 540? #1
jaybirdt
Holland New York
Iseki 1910f
I have not gotten a manual for my 1910 yet and the pto shifter housing was painted over so Im not sure which is the 540 as it has four in an H pattern.Thanks in advance also does anyone know where I can get a manual for this tractor? /forums/images/graemlins/confused.gif
   / Anyone know which of my 25 pto speeds is the 540? #2
Jaybirdt,
If you can't get the information from a dealer or anything like that you would have an option to get your self one of them hand tachometers, it would be kind of dangerous but you could do a trial and error with the different speeds. Just set your tractor at the PTO RPM range and just try each one. I would take caution at doing it this way. Get a tach that would allow you to measure at the center of the PTO so you don't have to deal with the splines. Another way if someone has a dyno meter, some shop, and there would be a charge but you could find what you need.
Murph
   / Anyone know which of my 25 pto speeds is the 540? #3
From my experience with other gray models, the lowest speed is probably 540.
   / Anyone know which of my 25 pto speeds is the 540? #4
   / Anyone know which of my 25 pto speeds is the 540? #5
Wow.... I thought I had enough with 4 PTO Speeds!! /forums/images/graemlins/blush.gif My shift pattern PTO Lever is on the lower left had side of the seat platform in the TA210 and it is a standard "4 Speed" type pattern with the lower left or number "1" position as the 540 speed.
   / Anyone know which of my 25 pto speeds is the 540? #6
Jaybirdt,on the H pattern,bottom inside, toward tractor,is 1st,outside is 4th. Top outside is 2nd and inside is 3rd. 1st is 540 rpm.
   / Anyone know which of my 25 pto speeds is the 540? #7
What engine RPM achieves the 540 PTO 1st notch RPM?
dont have a manual for my new to me TL 2300 so this is truly helpful.......thanks
   / Anyone know which of my 25 pto speeds is the 540? #8
My tachometer has an indicator and shows it at about 2400 RPM on the TA210.
John Deere 3025E (A53317)
John Deere 3025E...
PEMBERTON LR129-1123 RAKE ATTACHMENT (A56129)
PEMBERTON...
2017 Freightliner Bucket Truck (A55973)
2017 Freightliner...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A58375)
KNOW BEFORE YOU...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2018 Ford F-150...
2015 Chevrolet Silverado 3500HD Knapheide Enclosed Service Truck (A56858)
2015 Chevrolet...
