Anyone know which of my 25 pto speeds is the 540?
   / Anyone know which of my 25 pto speeds is the 540? #1
jaybirdt
Holland New York
Iseki 1910f
I have not gotten a manual for my 1910 yet and the pto shifter housing was painted over so Im not sure which is the 540 as it has four in an H pattern.Thanks in advance also does anyone know where I can get a manual for this tractor? /forums/images/graemlins/confused.gif
   / Anyone know which of my 25 pto speeds is the 540? #2
Jaybirdt,
If you can't get the information from a dealer or anything like that you would have an option to get your self one of them hand tachometers, it would be kind of dangerous but you could do a trial and error with the different speeds. Just set your tractor at the PTO RPM range and just try each one. I would take caution at doing it this way. Get a tach that would allow you to measure at the center of the PTO so you don't have to deal with the splines. Another way if someone has a dyno meter, some shop, and there would be a charge but you could find what you need.
Murph
   / Anyone know which of my 25 pto speeds is the 540? #3
From my experience with other gray models, the lowest speed is probably 540.
   / Anyone know which of my 25 pto speeds is the 540? #4
   / Anyone know which of my 25 pto speeds is the 540? #5
Wow.... I thought I had enough with 4 PTO Speeds!! /forums/images/graemlins/blush.gif My shift pattern PTO Lever is on the lower left had side of the seat platform in the TA210 and it is a standard "4 Speed" type pattern with the lower left or number "1" position as the 540 speed.
   / Anyone know which of my 25 pto speeds is the 540? #6
Jaybirdt,on the H pattern,bottom inside, toward tractor,is 1st,outside is 4th. Top outside is 2nd and inside is 3rd. 1st is 540 rpm.
   / Anyone know which of my 25 pto speeds is the 540? #7
What engine RPM achieves the 540 PTO 1st notch RPM?
dont have a manual for my new to me TL 2300 so this is truly helpful.......thanks
   / Anyone know which of my 25 pto speeds is the 540? #8
My tachometer has an indicator and shows it at about 2400 RPM on the TA210.
2006 Intellistrobe Automatic Flagger Assistance Device S/A Towabale Trailer (A55973)
2006 Intellistrobe...
Year: 2017 Make: Dodge Model: Charger Vehicle Type: Passenger Car Mileage: 105,664 Plate: Body Ty... (A56859)
Year: 2017 Make...
33ft Dovetail Flatbed Trailer (A56435)
33ft Dovetail...
2018 John Deere 1653 (A56436)
2018 John Deere...
2009 Dodge Ram 3500 Flatbed Truck with Liftgate (A55973)
2009 Dodge Ram...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
