Anyone know which of my 25 pto speeds is the 540?
   / Anyone know which of my 25 pto speeds is the 540? #1
jaybirdt
Holland New York
Iseki 1910f
I have not gotten a manual for my 1910 yet and the pto shifter housing was painted over so Im not sure which is the 540 as it has four in an H pattern.Thanks in advance also does anyone know where I can get a manual for this tractor? /forums/images/graemlins/confused.gif
   / Anyone know which of my 25 pto speeds is the 540? #2
Jaybirdt,
If you can't get the information from a dealer or anything like that you would have an option to get your self one of them hand tachometers, it would be kind of dangerous but you could do a trial and error with the different speeds. Just set your tractor at the PTO RPM range and just try each one. I would take caution at doing it this way. Get a tach that would allow you to measure at the center of the PTO so you don't have to deal with the splines. Another way if someone has a dyno meter, some shop, and there would be a charge but you could find what you need.
Murph
   / Anyone know which of my 25 pto speeds is the 540? #3
From my experience with other gray models, the lowest speed is probably 540.
   / Anyone know which of my 25 pto speeds is the 540? #4
   / Anyone know which of my 25 pto speeds is the 540? #5
Wow.... I thought I had enough with 4 PTO Speeds!! /forums/images/graemlins/blush.gif My shift pattern PTO Lever is on the lower left had side of the seat platform in the TA210 and it is a standard "4 Speed" type pattern with the lower left or number "1" position as the 540 speed.
   / Anyone know which of my 25 pto speeds is the 540? #6
Jaybirdt,on the H pattern,bottom inside, toward tractor,is 1st,outside is 4th. Top outside is 2nd and inside is 3rd. 1st is 540 rpm.
   / Anyone know which of my 25 pto speeds is the 540? #7
What engine RPM achieves the 540 PTO 1st notch RPM?
dont have a manual for my new to me TL 2300 so this is truly helpful.......thanks
   / Anyone know which of my 25 pto speeds is the 540? #8
My tachometer has an indicator and shows it at about 2400 RPM on the TA210.
New/Unused CFG Industrial MX12RX Mini Excavator (A57453)
New/Unused CFG...
2017 JOHN DEERE 544K-II WHEEL LOADER (A52709)
2017 JOHN DEERE...
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
LOT: (17 approx. ) Rolls of Chain Link Fence (LENGTH UNKNOWN) (A59076)
LOT: (17 approx. )...
2014 Volkswagen Touareg - Turbo Diesel - AWD - 189,609 miles (A55302)
2014 Volkswagen...
2015 WESTERN STAR 4900EX (INOPERABLE) (A58214)
2015 WESTERN STAR...
