Anyone have pictures of Quck Attach Handle Mods
   / Anyone have pictures of Quck Attach Handle Mods #11
SwampmanLA said:
I made it. It was raining here today so I went into the shop and removed all the metal that did not look like a handle extension.
Very nicely done. :D Much simpler than what I went through to move my to the left side of the steering wheel -- however I do like being able to manipulate mine with my fingertips and still have my left hand on the wheel, with the right hand on the lift/curl joystick...
I am taking JJ's idea on this one and probably going to order this
Surplus Center Item Detail
And then this
I will drill a hole on the left side.. Drop the cable either through the center console or down the side of the console, cross at the Treddle and come back up on the valves.
But, you guys can see your PT so if you have any ideas on additional items I should order, or maybe I should rethink this, I am happy to take all the input you can give.
Carl
   / Anyone have pictures of Quck Attach Handle Mods #14
When I installed the Aux hydraulic circuit on my 180 I used the same 3 spool valve that is on the 422, 425, and the red Pt's. I think it would be an easy fix ( relocate 3 spool valve ) for you guys that want the Aux circuit in a better location. The downside is that you might have to replace the joy stick with 2 control handles like I did, but all functions can be controlled very easily with your right hand. The picture shows the Aux. circuit handle to the far left side of the valve ( same location as on the 422,425, & red Pt's )
   / Anyone have pictures of Quck Attach Handle Mods #15
Though you lose the joystick's ease of use, you likely also get rid of the problem of the long, heavy joystick causing the lift to pop out of float position with your solution. Very nicely done, also...
   / Anyone have pictures of Quck Attach Handle Mods #16
And then this
Carl
Carl, I've considered this myself, to replace the manual linkage. Should you decide to proceed, please let us know how it goes, and how difficult it is to connect the cable linkage. My PT has Gresen valves, I think, and this cable control setup is for Prince valves, unless I'm mistaken. Not sure how that might complicate matters.
My manual linkage has some slop in it, so it is not as precise as I'd like, but it works better than most of my "shade tree engineering"... :p :D
   / Anyone have pictures of Quck Attach Handle Mods #17
I should mention that ...at the time I did the conversion on my 180 (2004)...Power-Trac was using Sauer-Danfoss valves on the 180, 422, 425, and the red Pt's.
What manufacture they used, before, or after 2004.... and presently is any body's guess. :eek: :D
   / Anyone have pictures of Quck Attach Handle Mods #18
I put the aux control handle on the left of the wheel like some others. Just 5/16" threaded rod covered with heat shrink tubing after fabrication, use heat to do the 90 degree bend. Some old throttle rod ends to attach to the existing lever - rod pivot bearings are slices from a 4" door hinge with the pin hole drilled and tapped for the 5/16" rod. They are attached with the existing access panel bolts - thread them into the approximate postion before covering the rod with the shrink tubing. I welded an short tab to the existing QT handle - plan on working fast and cooling the piece after welding it (I used a small MIG unit), to preserve the rubber handle (I took the handle off to do the welding). The bellcrank on the end of the threaded rod is another piece of the hinge welded to a nut. Lock it in the appropriate position with another nut - makes things adjustable. I made the length of the vertical piece coming up to the knob long enough that it can be reached with fingers while your hand is on the wheel for steering control. Works very nicely and becomes intuitive.
Don... that is way coo!!!! A very smart idea. I am not sure how it can fail. I may just have to steal it and make it my own...
Carl
   / Anyone have pictures of Quck Attach Handle Mods #20
Very slick, Don. Nice job! :)
LAND PRIDE RCR1260 5' ROTARY MOWER (A59823)
LAND PRIDE RCR1260...
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
2015 INTERNATIONAL PROSTAR (A59905)
2015 INTERNATIONAL...
excavator trenching bucket- one bucket per lot (A56438)
excavator...
2008 DOOSAN G25 GENERATOR (A58214)
2008 DOOSAN G25...
13042tx (A55973)
13042tx (A55973)
