Anyone have a portable fuel tank for carrying to jobsites/fields etc?
   / Anyone have a portable fuel tank for carrying to jobsites/fields etc? #12
And from a site advertiser: Auxiliary Fuel Tanks for Skid Steer Loaders | Skid Steer Solutions
   / Anyone have a portable fuel tank for carrying to jobsites/fields etc? #13
man, when i purchased mine in 2012, it was $700 incl shipping. prices sure have changed.
   / Anyone have a portable fuel tank for carrying to jobsites/fields etc? #14
I went with one of these as a solution that is the best I could find for my use case. I got the 58-gallon version and built a pallet for it. It was also $100 less a month ago.
   / Anyone have a portable fuel tank for carrying to jobsites/fields etc? #15
I made a cart to hold a 26 gal poly tank with a hand pump.
It isn't pretty but it's very functional. I roll it up a ramp to load on a trailer and wheel it around to fuel wherever it's needed.
If that sprayer tank has a bottom drain like mine I wouldn't trust it for holding diesel. I'd use a steel or HDPE oil drum.
   / Anyone have a portable fuel tank for carrying to jobsites/fields etc? #16
No Drain. It's had diesel in it for over 15 years with no leakage.
I built it from junk I had laying around so it doesn't owe me anything. I really didn't expect it to last this long but I still use it.
I could have used a small steel drum but I want tp keep the center of gravity low to make it more stable while rolling around. It would be too difficult to rig a hand pump to a drum laying on it's side without cutting & welding. There is also the possibility of leakage around the bungs as well as the difficulty in refilling.
The old sprayer tank I had seemed like the easiest build.
   / Anyone have a portable fuel tank for carrying to jobsites/fields etc? #17
I bought a rechargeable (with a cellphone charger) pump off Amazon for cheap ($75 or so?). 10 foot hose.
My buddy with his 40 series Deere kinda snickered at it a little bit until the pump for his 100 gallon tank in the bed of his truck took a dump while we were working it. Not sure why. Don't care.
He used my cheap little pump and it worked well. Not as good as his thousand-dollar setup when it worked right but for $75 it worked very well. At least he didn't get a diesel bath trying to hump 5 gallon cans up over his head. Which is very unpleasant. Bigly.
Sometimes 'KISS' (keep it simple stupid) works out. Sometimes not. But for the price of a bottle of good Bourbon.....??
   / Anyone have a portable fuel tank for carrying to jobsites/fields etc? #18
I use 55 gallon drums, there are a number of manual and electric pumps already on the market that thread right in the large bung.
Or you can build or buy a cradle and valve that threads into the small hole and lay if over so gravity does the work.
That’s about as cheap and simple as it gets.
Unless you drive a diesel and can tie into a pressure test port and let the trucks factory tank/pump(s) do the work.
   / Anyone have a portable fuel tank for carrying to jobsites/fields etc? #19
Pretty when it's all clean and dry, but all I see is a dirt and grit magnet and multiple sources of garbage to get into a fuel system.
And your still lugging cans of fuel around and how are you going to get your drum refilled?
   / Anyone have a portable fuel tank for carrying to jobsites/fields etc? #20
Those roller drum cradles are designed to pivot upright to refill.
They don't roll very well over rough surfaces though and there is no easy way to attach a pump when the drum is horizontal.
BUYER'S PREMIUM INFO LOT NUMBER 2 (A53084)
BUYER'S PREMIUM...
2018 Ford Transit 250 Cargo Van (A51692)
2018 Ford Transit...
7046 (A50322)
7046 (A50322)
2017 FREIGHTLINER M2 S/A SWEEPER TRUCK (A51406)
2017 FREIGHTLINER...
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
JOHN DEERE 6155M (A53084)
JOHN DEERE 6155M...
