Anyone drilled a hole in the end of a pallet fork
   / Anyone drilled a hole in the end of a pallet fork #31
ANSI has some strong rules regarding overhead guard modifications .
There is a product called DAGS that mounts to forks magnetically, rubber covered to keep loads from slipping.
   / Anyone drilled a hole in the end of a pallet fork #32
If the OSHA people ever saw some of the crazy stuff people do with forklifts they would probably outlaw them completely. :confused2:
You mean like putting a pallet on the forks and using it as a man lift? Who would do that?? <looks around guilty>
   / Anyone drilled a hole in the end of a pallet fork #34
Is that bad? :cryingeyesout:
   / Anyone drilled a hole in the end of a pallet fork #36
You're daft. no one would do that......
   / Anyone drilled a hole in the end of a pallet fork #37
The only thing missing is some ropes to the steering wheel and something to control speed and direction. I saw Mr. Bean do that.
   / Anyone drilled a hole in the end of a pallet fork #38
when i was a teen, my dad would go on the pallet to change light bulbs and i would run the lift. haha!
   / Anyone drilled a hole in the end of a pallet fork #39
We built a frame that has the hitch on the outer end of it for lifting tongues so as not to bend the forks unevenly. We have done that!
   / Anyone drilled a hole in the end of a pallet fork #40
I often say there is not as much abuse of equipment as there is equipment being used in a manner that was not considered when designing
(2) TRACTOR TIRES (A54757)
(2) TRACTOR TIRES...
2018 JOHN DEERE 410L BACKHOE (A52706)
2018 JOHN DEERE...
2019 HYUNDAI VC2530152-JS DRY VAN TRAILER (A56129)
2019 HYUNDAI...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A56129)
2017 FREIGHTLINER...
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXELL 150...
New/Unused Quick Attach Rock Breaker (A54865)
New/Unused Quick...
