Anyone drilled a hole in the end of a pallet fork
   / Anyone drilled a hole in the end of a pallet fork #31
ANSI has some strong rules regarding overhead guard modifications .
There is a product called DAGS that mounts to forks magnetically, rubber covered to keep loads from slipping.
   / Anyone drilled a hole in the end of a pallet fork #32
If the OSHA people ever saw some of the crazy stuff people do with forklifts they would probably outlaw them completely. :confused2:
You mean like putting a pallet on the forks and using it as a man lift? Who would do that?? <looks around guilty>
   / Anyone drilled a hole in the end of a pallet fork #34
Is that bad? :cryingeyesout:
   / Anyone drilled a hole in the end of a pallet fork #36
You're daft. no one would do that......
   / Anyone drilled a hole in the end of a pallet fork #37
The only thing missing is some ropes to the steering wheel and something to control speed and direction. I saw Mr. Bean do that.
   / Anyone drilled a hole in the end of a pallet fork #38
when i was a teen, my dad would go on the pallet to change light bulbs and i would run the lift. haha!
   / Anyone drilled a hole in the end of a pallet fork #39
We built a frame that has the hitch on the outer end of it for lifting tongues so as not to bend the forks unevenly. We have done that!
   / Anyone drilled a hole in the end of a pallet fork #40
I often say there is not as much abuse of equipment as there is equipment being used in a manner that was not considered when designing
2007 Anderson 25ft T/A Flatbed Equipment Trailer (A55852)
2007 Anderson 25ft...
2019 ROCK LINE RS8-32 80" X 9' HYD DROP DOWN TRAIL (A52706)
2019 ROCK LINE...
1991 FREUHAUF 40FT BELLY DUMP TRAILER (A56129)
1991 FREUHAUF 40FT...
2020 KUBOTA SVL75-2 SKID STEER (A52706)
2020 KUBOTA...
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2011 Ford F-150...
2011 CIRCLE M 32 FOOT GOOSENECK (A53843)
2011 CIRCLE M 32...
