Anyone drilled a hole in the end of a pallet fork
   / Anyone drilled a hole in the end of a pallet fork #31
ANSI has some strong rules regarding overhead guard modifications .
There is a product called DAGS that mounts to forks magnetically, rubber covered to keep loads from slipping.
   / Anyone drilled a hole in the end of a pallet fork #32
If the OSHA people ever saw some of the crazy stuff people do with forklifts they would probably outlaw them completely. :confused2:
You mean like putting a pallet on the forks and using it as a man lift? Who would do that?? <looks around guilty>
   / Anyone drilled a hole in the end of a pallet fork #34
Is that bad? :cryingeyesout:
   / Anyone drilled a hole in the end of a pallet fork #36
You're daft. no one would do that......
   / Anyone drilled a hole in the end of a pallet fork #37
The only thing missing is some ropes to the steering wheel and something to control speed and direction. I saw Mr. Bean do that.
   / Anyone drilled a hole in the end of a pallet fork #38
when i was a teen, my dad would go on the pallet to change light bulbs and i would run the lift. haha!
   / Anyone drilled a hole in the end of a pallet fork #39
We built a frame that has the hitch on the outer end of it for lifting tongues so as not to bend the forks unevenly. We have done that!
   / Anyone drilled a hole in the end of a pallet fork #40
I often say there is not as much abuse of equipment as there is equipment being used in a manner that was not considered when designing
2016 CATERPILLAR 325FL CR EXCAVATOR (A52705)
2016 CATERPILLAR...
2012 FREIGHTLINER CASCADIA SINGLE AXLE DAY CAB (A56129)
2012 FREIGHTLINER...
2014 Ram 1500 4x4 Crew Cab Pickup Truck (A53422)
2014 Ram 1500 4x4...
Crosley 10ft Hydraulic T/A Dump Trailer (A50322)
Crosley 10ft...
2011 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A52706)
2011 INTERNATIONAL...
CAT 938G Wheel Loader (A47477)
CAT 938G Wheel...
