Any Ideas for a Cheap Compact Rear 3 Pt Counterweight?
   / Any Ideas for a Cheap Compact Rear 3 Pt Counterweight? #71
If you look at post #25 I said I was going to build a ballast box. Here it is, 10 cubic feet so around 1500 pounds plus the steel.
It is now in the barn waiting for a paint job.:)
   / Any Ideas for a Cheap Compact Rear 3 Pt Counterweight? #72
   / Any Ideas for a Cheap Compact Rear 3 Pt Counterweight? #73
Thanks, I just did what other's have done. (copycat)
Looking forward to using it.
   / Any Ideas for a Cheap Compact Rear 3 Pt Counterweight? #74
Yup, but I was pretty proud of my scabbard idea (at least I think it was mine :D). :drink:
   / Any Ideas for a Cheap Compact Rear 3 Pt Counterweight? #75
Having sold my 3PT implements, and not having storage space for equipment, I discovered that I can easily mount a 50 gallon trash barrell on my 3PT, plan to fill it with water, and it will add enough weight to make my BX2200 loader lift better.
When done, dump the water and reuse the trash barrell.
Ron
   / Any Ideas for a Cheap Compact Rear 3 Pt Counterweight? #76
That's great! Missed it on the first look. Did either of you have to stuff the scabbard with something to support the wet cement pressure?
   / Any Ideas for a Cheap Compact Rear 3 Pt Counterweight? #77
Absolutely. I believe I used plywood (maybe 3/8" or maybe 1/2"). Also used a lag bolt to hold the bottom in place and also to provide a drain hole once the concrete set and I screwed it out.
   / Any Ideas for a Cheap Compact Rear 3 Pt Counterweight? #78
Pretty slick.:thumbsup:
   / Any Ideas for a Cheap Compact Rear 3 Pt Counterweight? #79
That chainsaw scabbard is INGENIOUS!!! Thank you for that.
   / Any Ideas for a Cheap Compact Rear 3 Pt Counterweight? #80
Uhhh, Cleveland? :D
Not going anywhere.
But I have often thought of adding a substantial (1500 lb) weight box to a tractor and haven't because I wasn't sure if it was fully OK to do or just sort-of OK to do. Not sure of the impact on the hydraulics and that invites my question.
I suspect that Luke's puzzling over "where you were going with this" was because there is no other obvious place to mount any counterweight on the rear of a tractor. If not the 3pt hitch then where ? If your 3pt hitch won't stand the counterweight, nothing else back there is going to. Of course size matters (and each person's situation and job to be done differs) but on an 81 horse tractor weighing around 9,000lbs with loader, etc. I have a 1400lb 7ft bush hog that stays on the rear most of the time. Seems to serve extremely well for a counterweight. And I'm definitely not worrying about the hydraulics handling it for the practical life of the tractor. To answer your question, I think it is fully OK.
With some very heavy 3pt mount items (like a 2 ton boom cutter) it is very advisable to make a support structure that allows the load to rest on the tractor frame and tow bar. Initially the load is on the 3pt but after the hydraulics bleed off the load is on the support structure. I don't think we are into that sort of overkill for a normal counterweight, however.
2005 Mack Vision Semi Truck (NOT RUNNING)(TITLE) (A50774)
2005 Mack Vision...
2016 Mack CXU613 T/A Wet Kit Day Cab Truck Tractor (A50323)
2016 Mack CXU613...
Farmall A Tractor w/Belly Mower (AS IS) (A50774)
Farmall A Tractor...
City of Tampa (1611) VIN: 1FTMF1CM1EFB40793, **Title MUST be transferred into buyer's name (A51692)
City of Tampa...
2012 Cadillac SRX SUV (A50324)
2012 Cadillac SRX...
2017 Ford Explorer AWD SUV (A50324)
2017 Ford Explorer...
