Any Ideas for a Cheap Compact Rear 3 Pt Counterweight?
   / Any Ideas for a Cheap Compact Rear 3 Pt Counterweight? #81
I suspect that Luke's puzzling over "where you were going with this" was because there is no other obvious place to mount any counterweight on the rear of a tractor. If not the 3pt hitch then where ? If your 3pt hitch won't stand the counterweight, nothing else back there is going to. Of course size matters (and each person's situation and job to be done differs) but on an 81 horse tractor weighing around 9,000lbs with loader, etc. I have a 1400lb 7ft bush hog that stays on the rear most of the time. Seems to serve extremely well for a counterweight. And I'm definitely not worrying about the hydraulics handling it for the practical life of the tractor. To answer your question, I think it is fully OK.
With some very heavy 3pt mount items (like a 2 ton boom cutter) it is very advisable to make a support structure that allows the load to rest on the tractor frame and tow bar. Initially the load is on the 3pt but after the hydraulics bleed off the load is on the support structure. I don't think we are into that sort of overkill for a normal counterweight, however.
Note Bene!
Steel and iron are more than three times more dense than concrete.
Anything you can do to add iron works in favor of a compact design.
On the garden tractor, I use lifting weights and disc brake rotors. ;-)
KUBOTA U55-5 EXCAVATOR (A51242)
KUBOTA U55-5...
1240 (A50490)
1240 (A50490)
Koyker Loader DoubleTine Bale Spear - Versatile for Round and Square Bales (A51039)
Koyker Loader...
2015 MACK ELITE LEU633 GARBAGE TRUCK (A51243)
2015 MACK ELITE...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
2007 Jeep Liberty (A50515)
2007 Jeep Liberty...
