Flail Mower Any Ford 918H owners?
   / Any Ford 918H owners? #31
Unless the pulley is wobbling there is nothing to do there being as it is bolted up to the shaft it should be running true to the shaft. Shimming is the only way to correct the cant of the pulley and shaft to the lower pulley that I can think of.
195F is pretty hot.
   / Any Ford 918H owners? #32
I actually have the canting issue solved. There’s no canting anymore. It’s just that the bottom pulley sticks out to the left about 3 mm more than the pulley on top. It looks like you can unbolt these with the hex screws. I’m wondering how much adjustment on the shaft is possible in order to move that pulley in or out on the shaft the proper distance to line it up with the top one and make the two pulleys lineup better.
   / Any Ford 918H owners? #33
Considering that the pulley assembly on these is a two piece unit, the hub on the shaft should allow for some wiggle room to move it in or out some and since you are looking for about 3/16 I think there would be plenty to allow for that.
   / Any Ford 918H owners? #34
Has anyone changed out the bearing assembly that supports the carrier assembly? The dealer wants $300.00 for one.
Thanks
   / Any Ford 918H owners? #35
Dealer is almost always going to be a rip off, clean the bearing up and find the number on the bearing then check with your local bearing supply.
   / Any Ford 918H owners? #36
Thanks
If that’s the bearing I think it is it seemed like it was just going to be a bear to get the mower disassembled to get to the bearing. I just held my nose and paid the dealer
TEST YOUR BID BUTTON! (A51242)
TEST YOUR BID...
1986 CATERPILLAR D6H HI-TRACK CRAWLER DOZER (A51242)
1986 CATERPILLAR...
2003 FREIGHTLINER FL80 DUMP TRUCK (A51406)
2003 FREIGHTLINER...
2020 PETERBILT 337 BOX TRUCK (A51222)
2020 PETERBILT 337...
2004 Dodge Dakota Ext. Cab Pickup Truck (A50323)
2004 Dodge Dakota...
2011 JCB 541-70 TELESCOPIC FORKLIFT (A51242)
2011 JCB 541-70...
