Flail Mower Any Ford 918H owners?
/ Any Ford 918H owners? #21
Really appreciate all the tips. I guess there’s more than one way to skin a cat as they say. Good news. Stuck bolt finally came loose after several days. Kept soaking it. Used the 50-50 mix ATF and acetone. Squared off the edges of the bolt with a dremel. Tapping with hammer and turning with vice grip. Finally heated it up with a torch, not to the red hot, but just to where it was smoking a bit. Not sure which of these was most critical but bolt is out. Now I just have to put everything back together again. LOL.
/ Any Ford 918H owners? #22
So I’ve got it all together but when I put a straight edge on these two pulleys there’s a slight gap on the top pulley. What would be the way to straighten this out if it’s even necessary. I’ve messed around with the jam bolts
but it doesn’t seem to do much.
/ Any Ford 918H owners? #23
Just a long-shot here but I hope you'll plan to check belt tension routinely. I do and grease per job, usually lasts per job. Changing belts isn't as big a deal as paying for them. I keep spare sets on hand.
/ Any Ford 918H owners? #24
Any comment about the alignment issue?? Also, do you have this particular mower. The manual shows the belt spec as being 5/8 by 48.8“. Obviously that’s an odd size. All the big box stores carry 48 inch. Does that .8 make any difference.
/ Any Ford 918H owners? #25
If our belts/sets are same 'size' it's really just a matter of having room/range to adjust. (bolt slots) Again, my OEMs are 69.5" and I'm also using both 69" and 70" which cost ~half as much for good ones at TSC. I wouldn't be afraid to try 48" or 50" if something between is spec'd. One size may be tougher to put on, one may have less room to adjust for wear.
/ Any Ford 918H owners? #26
Yeah, probably why it was more of a struggle to get them on then what others here said it would be. ( one guy even said he doesn’t even loosen the gear box bolts—don’t see how that would even be possible).
how about the alignment issue? how critical is that. I mean they are “pretty straight” and mower seems to run smooth. But do I risk ruining the bearing if it’s 2 mm off??
/ Any Ford 918H owners? #27
The gearbox needs to go toward the back of the mower while the pulley end needs to go toward the front. It will get straight, just takes some playing with to get there and keep the tension right.
The .8 difference won't matter as long as they are matched belts and you can get them on.
/ Any Ford 918H owners? #28
So originally I could put a straight edge and line up points A CD. But that obviously meant that the top pulley was canted in a little bit. And that was generating way too much heat when I ran it. I can’t get all 4 points aligned. The best I can do is get AB perfectly parallel to CD but that leaves the drive shaft pulley about 3/16 inch inward (to the right) compared to the lower pulley. The jam bolts just allow movement forward and back, not left and right. I don’t see how it’s possible to move that top pulley out toward the left and keep it parallel.
/ Any Ford 918H owners? #29
I would add shims under the pulley end to eliminate or reduce the cant of the pulley. Lastly you can add some shims between the extension tube and gearbox if you need the pulley more to the left after you have figured what is needed to get the cant out of it.
/ Any Ford 918H owners? #30
How hot would you normally expect the pulley to get after running it for about 20 minutes? I’m getting a reading of about 195F. That seems pretty hot but I’ve got no reference point on this. I’m assuming the geometry of the pulleys must have been like this before I put on the new belts so seems like I must’ve been running the mower like this for years. I do notice that the pulleys are held on by hex bolts. Would adjusting the position of the pulleys on the shaft make more sense than using shims?
/ Any Ford 918H owners? #31
Unless the pulley is wobbling there is nothing to do there being as it is bolted up to the shaft it should be running true to the shaft. Shimming is the only way to correct the cant of the pulley and shaft to the lower pulley that I can think of.
195F is pretty hot.
/ Any Ford 918H owners? #32
I actually have the canting issue solved. There’s no canting anymore. It’s just that the bottom pulley sticks out to the left about 3 mm more than the pulley on top. It looks like you can unbolt these with the hex screws. I’m wondering how much adjustment on the shaft is possible in order to move that pulley in or out on the shaft the proper distance to line it up with the top one and make the two pulleys lineup better.
/ Any Ford 918H owners? #33
Considering that the pulley assembly on these is a two piece unit, the hub on the shaft should allow for some wiggle room to move it in or out some and since you are looking for about 3/16 I think there would be plenty to allow for that.
/ Any Ford 918H owners? #34
Has anyone changed out the bearing assembly that supports the carrier assembly? The dealer wants $300.00 for one.
Thanks
/ Any Ford 918H owners? #35
Dealer is almost always going to be a rip off, clean the bearing up and find the number on the bearing then check with your local bearing supply.
/ Any Ford 918H owners? #36
Thanks
If that’s the bearing I think it is it seemed like it was just going to be a bear to get the mower disassembled to get to the bearing. I just held my nose and paid the dealer
2012 Gastron Boat w S/A Boat Trailer. (A61574)
2012 Gastron Boat...
2017 Ford Explorer AWD SUV (A59231)
2017 Ford Explorer...
2025 Swict 72in. Bucket Skid Steer Attachment (A61572)
2025 Swict 72in...
KIVEL 3500 PALLET FORK ATTACHMENT (A61572)
KIVEL 3500 PALLET...
2007 Chevrolet Silverado\ Silverado Classic Pickup Truck, VIN # 1GCEK14X27Z181945 (A61165)
2007 Chevrolet...
2012 INTERNATIONAL 4300 4X2 26FT NON CDL BOX TRUCK (A59911)
2012 INTERNATIONAL...
