Antique tractor pulls.
/ Antique tractor pulls. #1
Thomas
Epic Contributor
Lebanon,NH.
Kubota B2650HSD w/Frontloader & CC LTX1046 & Craftman T2200 lawn mower.
For those that attend also pull I like to read your thoughts.
Here in the northeast most antique tractor are consider 20 to 25 years old to pull.
Do you think its fair (example) that 49 Farmall will pull against 1980 JD?
Do you feel limitations should be set...Years up to/HP/Man.vs Auto tranny etc..
Watching JD LP720 & Massey 98 turbo (or even smaller weight classes) chew and dig for every inch,than 1980 JD 4000?? w/ease power up and blow by...for they have more advance tech in motor & tranny...not much fun to watch.
Its nice to see the youngsters pick the brains of the older antique pullers...ones that still do or have pull w/30's,40's,50's tractors...also the older puller giving advice.
I feel and somewhat see in time yesterdays older iron will show little interest come to tractor pulling events if some new rules & regs. aren't change.
Looking forward to your views.
/ Antique tractor pulls. #2
I'm not sure what sanctioning body (and their rules) your local pulls are under. Most have classes broken up according to age, with 1959 or 1960 as the break point. Older is antique. Newer would be "classic", "farm stock" ,"super farm" , "pro stock", ect... The antiques would have weight classes as low as 3500 lbs. on up to maybe 7500 in 500 or 1000 lb increments. The newer, bigger tractors usually start at a much higher weight break. Say 5500lbs and up.
Personally, I LIKE seeing the tractors of the 1960's and 70's pulling. I LOVE seeing a sharp 1066 IH blowing black smoke and running down the track, sled in tow. Just don't think it's good to see them competing directly against something from the 40's. And my pet pieve with tractor pulling? Letting the same tractor pull 8 times in one class with 3 or 4 different drivers, then slap on a few weights and pull it 6 times in another class. That gets kinda BORING for the fans. 1 hook per class per tractor would suit me just fine.
There are HUNDREDS of sanctioning bodies. Every one plays by different rules. That's to keep "outsiders" at a disadvantage mostly.
I've been to a few pulls that use a "percentage" instead of weight classes. They figure either weight pulled or distance pulled divided by weight of the tractor. Highest percentage wins. I've pulled in a few of those myself. Best part about percentage pulling is, you don't have to strip weight off or add weight to the tractor to get to a minimum weight for the class. Just "run what you brung".
Get a rule book for the sanctioning body you plan on trying. Study it. Realize that tractor pulling is like old time stock car racing. "Cheating" isn't cheating if you don't get caught. Most of the top contenders bend the rules as far as they can get away with. That's not even considered wrong. When you see a "stock" 1949 FarmAll M turning 4000 RPM, pulling 12,000lbs down the track at 10 MPH, it isn't quite a stocker. Some of these guys are SERIOUS. Serious rule benders! ;)
My FAVORITE form of pulling has sorta disappeared. We used to have a "farm class" pull at our county 4H fair. No modifications (other than "turning up the fuel screw" on a few diesels), stock everything. Farmers would unhook the baler and bring it to pull. It was more a social event than a competitive pull (for most of us anyway). It was a percentage pull. Lightweight 0 to 5000lb, middle weight 5001 to 10,000lb, and heavyweight, 10,001 and up. There was a "most weight pulled" trophy, usually won by the heaviest tractor there. Local Massey dealer blew everyone away for years with an 1155 (Perkins v8 diesel) weighted to almost 20,000lbs. Between that one and a 6030 Deere belonging to a farmer from just up the road from my parents, the black smoke would cover the 4H grounds for hours afterwards!
AH! The good ol' days!
Thank you Sir for your view.
Iagree w/you on rules & regs on tractor classes when it comes to pulling!!
Indeed the 4H days...from the fields to track...gotta love it when operator leans the fuel on JD R and plays the throttle and flames from the stack a long w/black smoke and gets a full pull.
/ Antique tractor pulls. #4
I used to pull at a track where they normally pulled antiques 1959 and older but 1 benefit pull a year was open to any tractor as long as it made the weight class. There was a 3.5MPH speed limit. Never once can I remember a newer tractor out pulling an older one. Several reasons for that probably as the antique pullers were more educated on how to set up their tractors and weight distribution. Also many with newer tractors thought all they had to do was to show up to beat 'the old junk' so to speak. Also here a tractor can only pull once in a class. Also the speed limit negated any power advantage.
/ Antique tractor pulls. #5
Our antique pull was a disappointment this year. At the Ozark Empire Fair they ran the garden tractor pull and the antique tractor pull at the same time. The garden tractors were next to the grandstand, and the antiques were on the outside. Every time an old tractor would start really working, some single cylinder super stock would fire up and completely drown out the music of the old iron.
The best pull of the day was an absolutely pristine John Deere B. Now, he may not have won, but he sure put on the best show. On the inside track, a John Deere 140 with absolutely minimum modification beat 95% of the field of heavily modified "super stocks". Everyone else was trying to get to the end as fast as they could before the inertia wore off. The 140 just sat on its haunches, grunted and pulled the sled right on down the track. I think another 40 pounds on the back, and he would have pulled the sled out of the gate.
Now there a good idea...for I seen some sled operators take rough ride.
Thank you for your view Sir.
/ Antique tractor pulls. #7
Hey Farm,
How about the 2500 lb class, there are some real good pullin Super A tractors out there that can dominate that class :)
Amen to the Farm Class, bring it in from the field !!!:D
Go to have a good time and socialize with people that have a common interest !!! I mean what the heck you gonna do with a bunch of ribbons anyway :)
Oh yeah, Im with you on runnin one tractor in one class !!!
Must of been hard for those that wanted to see both events...hmmm...and to see A/T puller in blue jeans & baseball cap not standing to far from puller w/fire suit & helmet...ahhhh yes the good ol days.
Garden tractor pulling hasn't really caught on in my area as most...some country fairs do offer garden tractor pulling for the tadpoles tho which is nice.
/ Antique tractor pulls. #9
Thomas said:
...Must of been hard for those that wanted to see both events...hmmm...and to see A/T puller in blue jeans & baseball cap not standing to far from puller w/fire suit & helmet...ahhhh yes the good ol days....
Just to be clear, they were side by side. The left foul line for the garden tractors was about 6 feet from the right foul line for the old iron. You could see both, you just couldn't concentrate on the antiques, because the GT's were between you and the action.
/ Antique tractor pulls. #10
Here in WA for the pulls I attend the rules are roughly like this:
classic: '61 to around '76
antique: '60 and older
Classics start at 8000# and go to about 18000# by 1000# increments. They must be factory stock exc for the exhibition class which can be basically anything (lhotrods, etc). Antiques start around 3500# and go to about 9000# by 500# increments. From there to 12000# (or so) they go 1000# increments. There are some weight subclasses in there on the lower end which I dont fully understand. I think theyre in place so very old or specialized tractors can compete. Antiques w/i a weight class only run against tractors of similar age. That is, a 5000# tractor built in '45 wouldnt run against a '60. As w/ classics the tractor must be factory stock.
Our pulls run in two lanes w/ only one active at any given time so the action is nonstop. When one lane is resetting the other is running. If you look at the photo forum you can see some of what shows up. I like the idea of factory stock vs anything goes. Its more interesting to see the older machines as they were. Also some really sharp restorations show up to play.
Lawn tractors also run but Im not sure what the rules are and they pull in a completely diff event so theres not a mix of tractors and lawn mowers on the infield together.
Now that I like to see. :eek:)
/ Antique tractor pulls. #12
Didn't you post a thread with some pics a few days ago? Man, that was a good looking group of tractors. I would love to attend an event like that.
/ Antique tractor pulls. #13
Its awesome for sure! Even w/ 2 lanes going it takes 3+ hrs to get it all done and there usually arent any reruns.
/ Antique tractor pulls. #14
That would be me. Im glad you enjoyed 'em! I love it when pics get posted of things like this esp machines that are working. What I posted is only a small part of what I took that day. In the end I wound up w/ 100+ keepers. My screen saver slideshow is getting pretty good. :D
/ Antique tractor pulls. #15
scott_vt said:
Hey Farm,
Forgot about the little guys! Back when we still had our 4H pull, there weren't too many smaller sleds around. My uncle tried to pull his '57 Cub one year. He just barely got the slack out of the chain. The sled never budged.
Times were simpler back then. Sure do miss them.
I'm having lunch with a rep from our local vol. fire dept. tomorrow. Planning on trying to sell him on the idea of having an old fashioned "harvest festival", along with antique farm equipment show, tractor pull, and swap meet. Nothing big, nothing earth shattering, just a bunch of locals getting together and showing the youngsters how we used to do things. Too late for this year, but maybe NEXT fall! Wish me luck!
/ Antique tractor pulls. #16
Wishin you LUCK Farm !!!
/ Antique tractor pulls. #17
Well, I wasn't told NO.... My idea didn't get a rousing round of applause, but was taken to the Fire Dept's Board of Directors. I was promised "my day" in front of them to sell my idea. They're looking for something to center a fall festival around as a fundraiser. I told him that he needed to consider how much money these "tractor nuts" spend willingly on their hobby/passion. If even a small percentage ended up in the Fire Dept's hands, they'd make out like bandits.
MONEY has a way of getting attention.
I'll let you know how the next round goes.
Also more profits for the consession booths while waiting ones turn to pull.
Maybe some half time displays...slow race & barrel race etc.
May the board listen..the best to you.
/ Antique tractor pulls. #19
Hope they go for your idea. I bet it would be a big hit.
2003 CASE 70XT SKID STEER (A64279)
2003 CASE 70XT...
2020 FREIGHTLINER 114 SD CEMENTECH VOLUMETRIC MIXER (A65643)
2020 FREIGHTLINER...
ASV RC85 Skidsteer (A66285)
ASV RC85 Skidsteer...
2004 Mack 613 Concrete Mixing Truck (A64194)
2004 Mack 613...
2009 International DuraStar 4400 Fuel Tanker (A62613)
2009 International...
2006 Dodge Ram 1500 Pickup Truck (A61568)
2006 Dodge Ram...
