Antifreeze Option
/ Antifreeze Option #1
New Holland TN75
I have a 2002 New Holland TN75 that needs a coolant flush. Rather than use the New Holland 73344306, could I use this as an option since it’s less expensive and available at the local part store.
/ Antifreeze Option #2
As long as it has anticavitation additives I’d run it. Make sure you flush all the old coolant out.
I’d also recommend running distilled water for the last pass before the coolant so you get any minerals from tap water out of it, if you plan on using tap.
/ Antifreeze Option
I learned a long time ago first hand how bad leaving tap water in the system is for radiators. So I always use distilled water now.
/ Antifreeze Option #4
Only go with it if you are flushing. As AntiqueIron said use distilled water. For in the future you should get a test strip kit and add SCA additive as needed. Something for down the road. There are a lot of people who don't realize automotive anti-freeze is not the same as heavy duty diesel anti-freeze and mix it. I don't mean that you did. It's easy to get the mess someone else created though.
/ Antifreeze Option
I called a New Holland parts place and their parts guy told me to drain it and just put in regular green glycol antifreeze.
2016 Ford Explorer AWD SUV (A61569)
2016 Ford Explorer...
2018 Holbart 210 MVP Mig Welder (A64194)
2018 Holbart 210...
2025 JMR 78in Dual Cylinder Grapple Rock Bucket Skid Steer Attachment (A61572)
2025 JMR 78in Dual...
2011 Ford Fusion Sedan (A61574)
2011 Ford Fusion...
2011 Chevrolet Express 2500 Cargo Van (A61573)
2011 Chevrolet...
Lucknow 360 Feed Wagon (A63688)
Lucknow 360 Feed...
