Another toothbar
/ Another toothbar #1
shaley
Platinum Member
Tidewater VA.
Ford '92 2120
I thought I'd post some pics of my bolt on tooth bar you guys help me build.
72" Woods FEL bucket 6 teeth. I thought based on my usage 6 teeth would work well for me. I've been using it for 3 wks now and works great. I can even get more firewood in the bucket; may never remove it. Bought the teeth on Ebay $5 each and the shanks as well from another Ebayer 6 for $58. Had a piece of 3/8 x 2" bar or I would have used 1/2 x 3" at least. Here are some pics. Welded with 1/8" E6013 DC+
/ Another toothbar #2
I wondered if those could be bought individually and then build a bar. I'll look into that. Thanks for the pics and info.
/ Another toothbar
Do a Ebay search for "Bucket teeth" and you will find both guys. The teeth and shanks are cast steel size 23 series.
/ Another toothbar #4
Thanks for the info, found 'em!!!!
/ Another toothbar #5
I checked them out and was wondering. A tooth is 4.99. the mounts are 53.99 for six or about 9.00 each. The set of tooth mount and pin are 24.95. I emailed and asked what the difference between buying them seperatly and as the set is and they responded the set contains the pin.
Is the roll pin worth 11.00???????? I don't understand this.
/ Another toothbar
Koss, I purchased the teeth and pins from Ebayer "Piedmonttractor" for $4.99. Piedmont wants $15.50 for the shanks and $2.50 for the pins so I purchased the shanks from Ebayer "Constructon_parts" at 6 for $53. Shipping at that time was $8.10 and I now notice it is $15. Hopes this clears up the conusion.
/ Another toothbar #7
Nice looking tooth bar. I'm jealous. Has anyone ever found these shanks that will fit over the bolt on edge of the HD bucket? I had looked a few months ago and was not able to find them.
/ Another toothbar
Fabco make shanks for a bolt on edge I think. Check their website. I believe these shanks pictured will work as well. That is why I spaced the holder bar so far rearward. My new bucket will have a bolt on edge so the V tip it will be lower by 1/2 " an forward by 1". Or see if the guy on Ebay will sell just one.
Shoup John Deere 918 Poly for Platform (A65640)
Shoup John Deere...
PRESURE WASHER TRAILER (A65643)
PRESURE WASHER...
Metal Peacock (A65583)
2017 FREIGHTLINER M2 WATER TRUCK (A65643)
2017 FREIGHTLINER...
Woods 15ft. Batwing Mower (A65640)
Woods 15ft...
2020 INTERNATIONAL LT625 SLEEPER (A59910)
2020 INTERNATIONAL...
