Another Toothbar Solution
/ Another Toothbar Solution #1
Anonymous Poster
Epic Contributor
Picture 1
The FEL has a heavy-duty bucket, but it still isn't suitable for aggressive digging. I purchased a heavy-duty toothbar thinking that it was going to be a good solution. The complaints were that it did not fit well against the factory knife edge. As you can see, the fit looks normal from the top.
Picture 2
This picture shows that there is approximately .500 inch gap between the toothbar and the bottom of the factory knife edge.
Picture 3
This picture shows the back edge of the factory knife edge. The holes shown were factory drilled and were of no use.
Picture 4
This picture shows a side view of the gap. There are 2 carriage bolts provided by the factory to hold the toothbar in place against the bucket sidewalls. The toothbar mounting brackets are in the inside of the bucket.
Picture 5
The solution I chose was to MIG weld a piece of 7/16, cold rolled steel, onto the toothbar in the gap area. The new leading edge was bevel ground, not flame cut. Seven holes were drilled in the toothbar frame to accept 5/8x11x2 inch, flathead socket bolts. The holes were counter sinked to a depth that would allow the bolt heads to be slightly below the surface. The side fastening factory brackets were also used with the provided hardware.
Picture 6
This is a top view of the toothbar, factory knife edge and the new leading edge. Refer back to picture 1 to see the before. Notice that the terminating point, of the bevel on the new leading edge, is only 1/8 inch in front of the factory knife edge.
Picture 7
This is a head-on view of the new knife edge. Refer to picture 2 for the before. The gaps in the layers really closed up well using 7 bolts.
Picture 8
This is a side view of the new knife edge. The bucket is tilted up 60 degrees or so. The new knife edge extends out to the edges of the bucket to help protect the bucket corners. Refer to picture 4 for the before.
Picture 9
This picture shows the gap filled with the new knife edge. Notice the weld areas around the toothbar holders. The back of the new edge terminates close to the back wall of the factory edge. I did not want any overhang that would trap mud. The nuts are grade L9 from Reliant Bolt Company. A coating of marine grease was applied to all mating surfaces, nuts, lock washers and bolts. There is approximately .050 clearance between the bucket surface and the new knife edge so that the toothbar assembly will slide on. I removed the complete toothbar assembly once to make sure it could be done - no problems. Bolting the toothbar assembly down to the bucket increased the buckets rigidity tremendously.
Picture 10
This is a photo of a simple jig used to safely cut the length of the flathead socket bolts on a vertical bandsaw. It is made out of a square nut and a washer soldered to the bottom of the nut. This jig holds the bolt parallel to the work table. I did not want any threads sticking out past the nuts for obvious reasons. I hope this thread will be of help to somebody. The bucket is solid now.
R_squared,
That turned into some project and you did a wonderful job!
I wonder though, could you not have just slid the toothbar into the bucket until it could go not further? Looks like it would have pulled in pretty close and tight if you had done that.
My tooth bar is different than that one, being two pieces of flat stock welded into a vee that slipx over the cutting edge. THe teeth are welded onto that "new edge" and it is held on with only one bolt at each end...different animal I know.
I think I have seen pictures of the kind of tooth bar you have, and if I remember right it looked like those were just pushed all the way into the bucket and bolted in place.
In any case, I wish I had your metal working skills!
Henro,
Thanks for the complement. That was the first thing I tried. If you look at picture 2 and imagine pushing the toothbar in more, the slope of the toothbar holder causes the toothbar frame to rise up off the bucket surface. There was a choice of a gap under the bucket or above the bucket. The toothbar frame was 3/4 inch thick and another 1/2 inch would have made it 1 1/4 inch high in the bucket for the dirt to pass over. The easiest solution would have been to cut off the factory knife edge, and then the toothbar would have jammed properly. I new the toothbar would be removed from time to time so I wanted to preserve the factory knife edge. Another issue was preventing the factory knife edge from wearing prematurely. The new leading edge should make the bucket last longer. I was surprised that the steel used to construct the bucket was pretty easy to drill through. I used a Unibit.
/ Another Toothbar Solution #13
Nice job but I think who ever got u the tooth bar got the wrong one.
It looks like it was made to bolt on the extra straight edge
and tooth bar.
/ Another Toothbar Solution #14
</font><font color="blue" class="small">( Nice job but I think who ever got u the tooth bar got the wrong one.
and tooth bar.)</font>
I believe that's an ATI bar. Nice fab job. Like I've said many times before, "If you have the proper tools and knowledge, any job can be mastered"
Daryl
Forage Services, L.P.
/ Another Toothbar Solution #15
When you purchased your toothbar did you buy it off the shelf or did you give the manufacture the size specifications and they were suppose to make it to fit your bucket? You certainly did an excellent job, but I just ordered a toothbar and the manufacture wanted to know specs like thickness of the bucket edge, depth, length, etc. I simply can't do the wonderful things you did.
It was an off-the-shelf purchase for a 6 foot bucket. The instructions said that the toothbar would fit all bucket edges, but not those with a bolt-down knife edge. The Rhino HD bucket had a welded-on knife edge. I've read older posts where people were in the same boat with having a gap under their toothbar and they were not sure if it was ok or not. Some other older posts talked about whether the two hold down bolts on the sides of the bucket would be sufficient enough. Other more recent posts talked about premature bucket knife edge ware. This solution addresses all of these issues. I hope this post will help other members who are looking to purchase a toothbar, see the various geometries they can encounter. Maybe someone can come up with a better solution to accomplish the same thing. That's what it's all about!
15-19.5 Tire and Wheel (A68134)
15-19.5 Tire and...
2000 KENWORTH T800 CRANE TRUCK (A67714)
2000 KENWORTH T800...
2014 Ram 2500 4x4 Crew Cab Pickup Truck (A64194)
2014 Ram 2500 4x4...
2012 COMPTANK  ACID TRANSPORT TRAILER (A67714)
2012 COMPTANK...
2016 JOHN DEER 1600 TURBO SERIES II (A66091)
2016 JOHN DEER...
2023 VOLVO L90H WHEEL LOADER (A65053)
2023 VOLVO L90H...
