Another Storage/barn thread
   / Another Storage/barn thread #1
edkemper
Klamath Falls, Oregon
JD 210LE, Case 580CK Series B Backhoe, 1991 WoodMizer LT40 Log Mill, 1989 JD450E Crawler Tractor, FordsonMajorDiesel
I have a few hundred acres. I'm in the process of clearing fence lines and putting in roads so I can start construction on my home. I need a storage barn for my equipment (John Deere 210LE tractor/Case 580 Backhoe, a portable log mill, a couple of large/small trailers along with building supplies, tools and other misc. stuff.
I need to build DIY (more time than extra money) to house my needs before starting to build my house. A Pole Barn is the likely solution but I am having a hard time finding plans for what I need.
Anyone had similar needs that can share what they built and if they are so inclined, share their plans. I'm going to be moving a 32' 5th wheel trailer to live part time in while on the property building. I'd like to put a pole barn structure over that to protect me from the weather also.
As I understand my local laws, I can build Ag structures without approved plans/permits/inspection.
Any help and/or advice would be greatly appreciated.
   / Another Storage/barn thread #2
All I can say ed, is to build that thingBIG!
When ye think ye have it the right size, add more. A man can never have enough roofs on his place for all his stuff.
   / Another Storage/barn thread #3
Yep. I can 2nd this thought. It is amazing how quickly open storage space gets utilized.
MoKelly
   / Another Storage/barn thread #4
In the world of building, a pole barn is about as simple as they come. You just decide on how wide and how long you want it, then start drilling holes for the posts. Since you are looking for plans, I would caution you that taking on something like this for the first time can be a bit intimidating. Getting the walls lined up straight is the easy part. Setting the trusses or building rafters is where things can go wrong.
How wide do you want it? How tall will the walls be? Length isn't as important since it's all repetition once you figure out your span. Do you want it wide open on the inside or are you OK with posts? Will you have or want lean to's coming off the sides? What type of flooring will you want? Dirt, rock or concrete?
If you are going with concrete flooring, then stick framing or a metal kit become competitive. Will you want rooms in there for specific purposes? Will you put in a bathroom? Place to sleep? Kitchen area?
What type of door and how big does it need to be? How many? Some like to have a big door on either end of their buildings, others want multiple doors side by side.
All barns start out on paper as a square. You decide how big, then you figure out what it will take in materials, and add up the cost. For some, the time it takes to do all this makes it more viable to hire a pro who will come in and get it done so you can focus on doing other things.
Good luck,
Eddie
   / Another Storage/barn thread #5
Daggone it, old Eddie has to come in here and mess up a good redneck building plan with professional knowledge:shhh::shhh:
Well, the old boy (that'd be Eddie) does know his building bidness, so maybe we'd better listen when he talks.
Eddie,
This Eddie is listening.
I've been intimidated all my life. :eek:
I have time and am not in a hurry. My learning curve is fairly short. I tend to measure twice before I cut. I also have common sense. I've also learned I can't do what and how I used to do things. So now I use my brain and safety equipment.
20-24 feet would be great.
Gotta get just under 12 foot tall backhoe inside. So probably 16'. Keeping it at 4 foot dimensions.
I understand that.
Posts are not a problem for me. Get it dry and I can maneuver things around. It'll be basically a covered parking lot. With longer overhangs.
If you mean like carports on the sides, not planned. I need weather protection.
Dirt, over time, I'll add gravel.
Nope.
I'm building a house for those needs. Later I'll build a workshop with a concrete floor to do work and maintenance.
At first, just covered. I'll add siding later as I mill the lumber (in my spare time :eek: ).
Big doors on the ends after it is closed in.
I'm retired and won't have to leave the property to make a living. This doesn't have to be completed in a month. If it takes me a couple of dry seasons, so be it. DIY is why I bought all this land and am acquiring heavy equipment. Now I get to do the things my dad taught me for myself. Building things and structures has always been part of our lives. Plus it keeps me out of my wife's hair.
PS: I'm/we're building our "real log home" with our own hands. So a covered pole barn isn't a real challenge once we can plan out the how to. I can get old power poles from the local power company. I can rent the post hole digger (not the two person hand held). I have the backhoe and loader/box scraper. I can mill the lumber from the trees on my property. But I will buy the trusses from the local building supply.
Ed
   / Another Storage/barn thread #7
From what you said, this should be a pretty simple build. First thing is the size of the building. 24 feet wide is an easy build for trusses. No need for posts or anything fancy. Going with 16 foot walls is extreme, but doable. I would measure you backhoe and then add a foot for the thickness of the header door before committing to the wall height.
Once you decide on the size, you have to get the dirt work done. Flat pad at least a foot bigger then your building and then sloping down and away. Nothing causes more problems for a pole barn then standing water at the poles.
For the height you want, I would want the poles in the ground at least 4 feet. Space them every 8 feet all the way around except where your big door is going to be.
What are you going to use for your siding?
Eddie
Eddie,
Good to hear.
Backhoe is reported to be 11.2 ft high. So a 12' door is required. So maybe it'd be better to go 14' walls? Odd number but doable. That should be the tallest piece of equipment I'll need to get in.
Got it. I have a great neighbor (Logger) that has two dozers. He can cut whatever I need. So this is also doable. Plus my equipment to perhaps finish grade.
Also doable. Either with power poles or I can mill up to 20' cants. Probably 6x6s would do.
Easy peazy. Thanks
At first, just need to cover (metal roof). With long (4') overhangs, it should initially do what I need. Mostly keep the snow off.
However, as time goes along and from my other building projects, I will have lots of either left over lumber from first cuts (flitches) of logs or mill 2x whatever sizes I can manage. No reason to buy when I have a sufficient supply of trees and can get logs from my neighbor. Logs are cheap. The milling is another example of having time and not being in a hurry.
I really appreciate the easy plan you provide. No problem understanding the idea.
Thank you my friend.
Eddie,
On second thought, there is no reason why I can't extend the backhoe to go through the doors. So perhaps 12' walls might be doable. The only question is the height clearance of my 32' 5th wheel travel trailer.
Just an afterthought.
   / Another Storage/barn thread #10
Eddie,
It's a 5th wheel now. In 5 or 10 years when you get bored, it may be a 45' diesel motorhome. Do yourself a favor now and make it large enough to handle a large RV, larger than you own now. Wide enough for all slideouts to be out, high enough for any conceivable situation with an RV. Wish I had.
Utility Cart (A59228)
Service Truck (A59230)
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2011 MULTIQUIP LIGHT PLANT/ FUEL TANK TRAILER (A58216)
2011 MULTIQUIP...
1987 CATERPILLAR D6H HIGH TRACK CRAWLER DOZER (A59823)
1987 CATERPILLAR...
