another snow plow adapter thread - b7800 & weston
   / another snow plow adapter thread - b7800 & weston
Yes, but why when you already have hydraulics available? Plus you have to buy a controller.
I am thinking about how to get the power angle working. My hydraulic remote is in the rear, so I would have to have some really really long hydraulic lines made up, which are usually not cheap... probably 2x 15' lines.
If I can just wire up this pump to the battery and rig some kind of basic controller it maybe another option for me...
   / another snow plow adapter thread - b7800 & weston #12
Picked it up today. It's a Western plow, 7 feet, and all the mechanicals appear to be in order. The guy even threw in the pump which was used on the pickup truck it came from. I got everything for $125 (plus another $20 trailer rental) which seems like a pretty good deal to me. I don't think I will need the pump, I will use the tractor hydro.
I didn't realize how big this thing was until I saw it in person. It's huge. I hope it's not too big for the B7800, i can see now why cutting down the frame and keeping the weight closer to the pins would make it easier to manage. Now I just need to figure out a way to mount it.
I have a 7' Western on my 32 HP Deere 4300, and it handles it very well. I'd think your B7800 would as well. However, I mounted the plow on the tractor, not on the FEL. I think that being farther out front, it may move the tractor a lot more when attacking snow. Mine also has the short A-frame that brings it up closer.
Without the FEL, leaves the FEL hyd. couplings and joy stick free to control the three rams. Another plus. :)
Thanks for the info and pic... I know you may not be able to see my pictures because photobucket wants me to pay them now. Looking at your pictures, my plow looks beefier. I have 3 springs and what I believe is a shock absorber where-as you seem to only have 2 spring and no shock. Any idea what the weight of your plow?
Good idea about mounting directly to tractor and using FEL hydraulics. I did not think of that. My FEL is supposed to be "easily removable" occording to manual, maybe it's time to find out!
Thanks,
   / another snow plow adapter thread - b7800 & weston #14
Buying hoses will be cheaper. If not up front it will in the long run when the pump moter fails.
   / another snow plow adapter thread - b7800 & weston #15
Your battery and alternator are more expensive the 2 1/4" lines from your rear remotes-don't hook it up to the tractor that way!
   / another snow plow adapter thread - b7800 & weston #16
Thanks,
The weight is 575#.
My FEL is very easy to drop off and re-attach (most time is taken just disconnecting or connecting the hyd. lines :) ). I made the plow hitch so it is easily tilts up on pins in the MMM front brackets, and then with two bolts, attaches to the weight bracket. I keep the plow and hitch together, and have casters in the plow skid brackets, and a 4 wheel caster dolly under the A-frame. At most, a 10 minute job to switch from FEL to plow, or back again.
   / another snow plow adapter thread - b7800 & weston #17
beenthere, can you take some more pictures of how the frame is mounted to your tractor and how the plow mounts to the frame? I like your setup.
   / another snow plow adapter thread - b7800 & weston #18
I ran a battery operated Mayer plow on a 6.2 GM 4 x 4 and can tell you that the those 12 volt hydraulic pumps draw HUGE power.
The GMC had dual huge batteries (and new) and more than once I had to walk home when I plowed at night.
Think of it as using your starter every few minits and how short a time that battery will refuse to turn over your motor.
Plus most compacts do not have all that many amps at the alternator.
   / another snow plow adapter thread - b7800 & weston #19
There are some previous pics and discussions about front plows, and a search on Western Plow may give you some of the insights of several on the front mount.
Here is a pic of the hitch (plow adapter) that I had fabricated to connect the front end of my Deere 4300 with the Western plow short A-frame that was available around year 2000 when I put it together. This pic is after fabrication and white primer paint. Does this help?
   / another snow plow adapter thread - b7800 & weston #20
You need a bigger alternator.
COSMO SPIN SPREADER, 3PT (A52708)
COSMO SPIN...
Club Car Electric Cart (A55758)
Club Car Electric...
EDGER & FRONT TINE TILLER (A58374)
EDGER & FRONT TINE...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
ROLLING METAL RANK & CONTENTS (A58374)
ROLLING METAL RANK...
Terms & Conditions of (Buying through EquipmentDealz Auction) Final (A59213)
Terms & Conditions...
