another pto question
/ another pto question #1
jeff77indy
Grantsburg, IN.
2007 4110 Mahindra w/ M112 loader.
I know what transmission driven, live and independent pto types are as I have been around tractors all my life, but what type does continuous pto fall under?
/ another pto question #2
the only continuous pto that I can think of is one that comes right off the crankshaft to run a hyd pump. I don't think there is such an animal for the rear pto as it needs to stop with the engine running.
/ another pto question #3
I think you might be right. i had a ford 2 n that had a hydraulic pump that was right off the engine. the only other thing i can tink of is they are using continuous in place of the term INDEPENDENT /forums/images/graemlins/confused.gif
/ another pto question #4
The manual for my old IH2444 talks of a continuous PTO, however it has a 2 stage clutch type. I suppose they mean it will still run even when stopping/starting and changing gears.
Ben
/ another pto question #5
I think most two stage clutches will initially stop the drive train the puching the pedal further will disengage the pto. Yes, the PTO will run when stationary plus the pto kicks in before the drive train to allow an implement to get up to pto speed before moving if desired.
/ another pto question #6
Wayne,
Yes that is the way they work. However I was concerned when I first got my old IH. The manual said continuous running PTO and it was!! Someone had changed the clutch and since they did not use the PTO, they had never adjusted the second stage. I figured it out and adjusted it and all is well now.
Ben
/ another pto question #7
It also would allow direction changes while keeping the implement spinning.
2015 PRENTICE 2384C LOG LOADER (A64276)
2015 PRENTICE...
Year: 2011 Make: Chevrolet Model: Express Vehicle Type: Van Mileage: 118,735 Plate: Body Type: 3 (A59230)
Year: 2011 Make...
2025 Polaris Ranger Premium (A60462)
2025 Polaris...
2013 CORPUS 40FT T/A CONTAINER CHASSIS TRAILER (A59914)
2013 CORPUS 40FT...
2009 INTERNATIONAL WORKSTAR BUCKET TRUCK (A63276)
2009 INTERNATIONAL...
3148 (A63117)
3148 (A63117)
