Code54
Elite Member
- Joined
- Aug 20, 2005
- Messages
- 4,420
- Location
- Putnam Co. West Virginia
- Tractor
- Kubota MX5100, Kubota BX25D,1957 Farmall Cub Lo-Boy Kubota KX91-3, BCS 853
A while back I asked for some advice and information on building a land plane. I finally got it all wrapped up and together.
It is a 6' wide model
Little over 5'5" long
Duel straight blades - have about an 1 1/2" of up and down adjustment.
used 5/16 5"x3" angle as the backer for the 1/2' thick blades. Reinforced the angle with some 1/4 angle just in case
used a 1" solid rod to run from the front blade to the front/rear support for additional bracing (Figure it would be taking most the stress)
The side are "I" beams (bottom inside of the "I" removed to make a better skid
On top of the "I" beam there is more of the 5/16 angle to add some extra height
My front to rear brace is a smaller I beam I had laying around
The main cross members are 6" wide 1/4" thick "C" channel
Whole thing is coated with a thick coat of Raptor black bed liner
I am not sure what it weights but it is darn heavy. May take the time to calculate it one of these days when it is raining out.
The majority of it was made with stuff we had laying around but I did have to get a few things and the blade.
Cant wait until it is dry enough around here to use it!
