another land clearing question
/ another land clearing question #1
kjonfc
Washington, MO
IH 300, Ford 8N, LS G3038
I have what used to be a pasture and before that, it was an orchard of some sort. There are a few sand plum trees there, but it's mostly cedar and locust trees. Some of the latter two are up 12". Most trees are around 6-8". The cedars I can deal with, but my question is, What do you do with those thorn covered locust trees? Just getting them out they leave thorns everywhere and I could get a new tractor if I have a nickle for every one I've pulled out of a tire. The green slime has worked pretty well so far, between tractors, atvs, etc. I should buy stock in that company. I have literally hundreds of locust trees and they shed limbs all over the place while they're standing so getting close is even a challenge sometimes. Just wondering how some of you handle this menace.
TIA
-Kyle
/ another land clearing question #2
You might be a good candidate for foaming tires. It's very popular in construction as flats cost a lot of $ when work stops. And it gives you some more weight without putting stress on your drivetrain.
/ another land clearing question #3
Why not hire a tracked dozer to clear all you want? Problem solved or at least a lot more manageable.
/ another land clearing question #4
Second on hiring a tracked bulldozer. Or possibly a 10,000 pound tracked skid steer.
Call your local Tree Service for a bid.
/ another land clearing question #5
I wouldn't foam tractor tires it makes them ride horribly I've also heard it will void warranties
The place has been left alone for years and I'm not in a huge hurry to try to get it back to open pasture. Basically, I have more time than I have money. I dont have time as in nothing else to do, I dont even live on the place, just that there's really no ROI to justify hiring a dozer or a big skidsteer to come do it. I'm not going to be running livestock on it (besides the deer that are already there) or planting anything more than a possible food plot. I just wanted some open area to maybe set up a 500yd shooting range for my own personal enjoyment and to get it back a little bit closer to how I remember it as a kid.
I was just wondering if others have this kind of problem and how they handle it. I will look into the foam tires, but if it makes for a terrible ride and voids warranties, then it won't be an option.
/ another land clearing question #7
If you doze a locust, you will have saplings everywhere. Very hardy, will grow well from roots. If you short on budget, buy some torredon, girdle tree, spray. Those thorns will puncture a tire min 2 years after dead. Years ago, my broth n I cleared 4 acres of those honey locust by hand. We kept logs after skinning with machete. Burned branches and thorns, raked and burned again, lots of labor.
I walk my land very regularly. Noting any locust tree or sapling. Always return with hachet/saw and torredon. Done have to cut down, just kill. Btw, use torredon sparingly, will sour ground for any broadleaf, aka clovers..good.
/ another land clearing question #8
Probably have it dozed for less than the cost of one ruined tractor tire. Then the saplings can be managed with poison and a good brush hog. But do it however you wish. It is your time and $$
I have probably 35 acres I want to reclaim, part cedar and part thorn covered honey locust. The cedars, while I can probably only get a couple of boards each as they taper quickly, I will mill into lumber (no sense letting them go to waste), the locust was my concern with all the flats. I guess for now I'll just try something like ultraseal bullet proof. I know this topic has been beaten to death here so I won't labor it much here. I've used slime in my tires already and it has done an ok job and seems to be ok for the atvs and such, but I wonder if I need to take the tires off and clean them up before putting the ultraseal. Or if ultraseal is that much more superior to slime that I should even worry about it. Slime is holding for now, I have to put air in 2 tractor tires about once every two weeks and not even that much then.
vortex paint sprayer MARUYAMA (A64553)
vortex paint...
2023 GERINGHOFF PATRIOT RD8R30" CHOPPING CORN HEAD (A64278)
2023 GERINGHOFF...
VERMEER BC1000 XL BRUSH CHIPPER (A67147)
VERMEER BC1000 XL...
2015 INTERNATIONAL 4300 4X2 26FT NON CDL BOX TRUCK (A67147)
2015 INTERNATIONAL...
2024 JCB 35Z-1 EXCAVATOR (A65053)
2024 JCB 35Z-1...
2007 TORO 3300-D CART (A66091)
2007 TORO 3300-D...
