Another John Deere 1050 hydraulic problem.
   / Another John Deere 1050 hydraulic problem.
Not unbearable but you just don’t want to hold it for a long time . And that’s when everything quits working
   / Another John Deere 1050 hydraulic problem. #12
My 2240 already had a loader when I bought it but, the old 2 lever valve was bad. I replaced it with a joystick type. It does not use the power beyond port and is setup closed center. The pressure line is teed into the hard line going to the lift box and rear remote. The out line is plumbed into the filter housing. I think it's a kit that be bought from JD.
That’s how it’s hooked up right now. This tractor had the old style 2 lever control and was replaced with a joystick. I feel like I’m still missing something. It’s driving me crazy.
   / Another John Deere 1050 hydraulic problem. #15
The problem got fixed. So I thought the loader and bush hog went up and down with no problem and I cut the pasture (15 acres) with no problem then didn稚 use it for a couple of weeks maybe 2-3 went out and try to cut it and the bush hog wouldn稚 raise up as I was trying to set the cut height. Neither would the loader.
So it didn't get fixed?
And the three point hitch worked before you added the loader? Does it have power steering? The plugged line shouldn't be plugged. Ill look and make a diagram tomorrow.
Am I right that I'm only seeing six lines going into the valve block? There should be seven: spool one +(2 lines) spool two = (2 lines) supple, return and power beyond.
The power beyond is the plug on the left side that you can’t really see. It’s plugged Up now.
Yes the 3 point hitched worked before and it doesn’t have power steering
I need to see how the lines are suppose to be hooked up to the joystick. And coming from where on the tractor
   / Another John Deere 1050 hydraulic problem. #19
Got it. I have a 950 with a loader mounted valve like you have. It's at my widowed mothers ranchette, but depending on forgetfullmess, I'll make you a diagram of how mine is piped. I should be able to subtract the PS power divider from my diagram.
Do you have the factory service manual? If the answer is no, please PM me.
   / Another John Deere 1050 hydraulic problem. #20
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
2019 KUBOTA U35-4 EXCAVATOR (A52706)
2019 KUBOTA U35-4...
John Deere 4600 (A53317)
John Deere 4600...
2014 International Durastar 4300 SBA 4 x 2 Water Truck, VIN 3HAMMMMN4FL510006, Cummins Turbo Diesel (A59076)
2014 International...
Ingersoll Rand SD-116DX TF (A53317)
Ingersoll Rand...
JOHN DEERE 469 BALER (A58214)
JOHN DEERE 469...
