Another John Deere 1050 hydraulic problem.
   / Another John Deere 1050 hydraulic problem. #1
krisbodean85
john deere 750
Ok so I was having a heck of a time tryin to figure out how to hook up my joystick controller on my JD 1050 with jD fel. But I finally got it it was the pby plug missing an o ring. Now I haven稚 ran it much maybe a couple of hours since the fix. Well about a week or so ago I started bush hogging and notice that the bush hog when I tried to lift it up it wouldn稚 move neither would the front end loader so I cut the tractor off and look around and can稚 visually see anything. Crank it again and nothing I had to leave it in the field over night came back the next day and the bush hog would lift and so would the fel very slow on both of them but they lifted enough for me to bring it home. So today I went out and try to figure out was going on so I cranked the tractor and it did the same thing I could hear the pump so I let it run for a while went behind the house about 50 yards and bush hogged and when I went to raise the bush hog nothing again. I think it痴 only working when it痴 cold and once it gets hot it quits working. I知 at a lost please help. Thanks for all the input.
And I don’t heard the pump when I’m calling for it with the levers
   / Another John Deere 1050 hydraulic problem. #3
Can you post a photo of how you attached hoses to tractor to supply oil for FEL valve? Did tractor come with scv?
Anyone have any advice? Really need to get my tractor going
   / Another John Deere 1050 hydraulic problem. #6
Question.. did you have a reason to connect it this way, or was it by trial and error?
Sounds like some restriction isn't allowing the hyd. fluid to flow, thus heating the oil and then failing to work.
Puzzles me what the capped/plugged line is supposed to go to..
More pics of where these lines go to might help with answers.
Edit:
I see you had another thread going about the joystick problems a few months ago.. also pics there.
https://www.tractorbynet.com/forums...-john-deere-1050-joystick-installation-2.html
Were the March '18 problems resolved or is this a continuation of those problems? just wondering..
   / Another John Deere 1050 hydraulic problem. #7
getting air in the lines when it's hot?.
The problem got fixed. So I thought the loader and bush hog went up and down with no problem and I cut the pasture (15 acres) with no problem then didn’t use it for a couple of weeks maybe 2-3 went out and try to cut it and the bush hog wouldn’t raise up as I was trying to set the cut height. Neither would the loader.
I works somewhat when you first start up the tractor the loader and 3 point hitch are jumping as I’m raising them.then I’m assuming once it gets hot it quits working. I get nothing till it cools off what it seems like
   / Another John Deere 1050 hydraulic problem. #10
the hydraulic reservoir should be cooling the fluid enough that you don't have this problem!.. is the fluid getting really hot?..
2020 Freightliner Bucket Truck (A55973)
2020 Freightliner...
New/Unused 2 Post Car Lift (A57454)
New/Unused 2 Post...
ford Taurus 2014 (A56859)
ford Taurus 2014...
2000 PETERBILT 379 MID-ROOF SLEEPER (A58214)
2000 PETERBILT 379...
2020 MACK GR64FT (A58214)
2020 MACK GR64FT...
Case-IH 160 Puma (A57148)
Case-IH 160 Puma...
