Another Homemade Root Grapple !!
   / Another Homemade Root Grapple !! #11
I like the big bite you can get - good for bushy tree limbs. I'd be concerned the arms would bend unless you are planning cross-bracing. It's funny how sideways things get even when you think you're biting evenly. I know the much shorter arms on my Millonzi are braced almost to the end, and they have bent a little. Admittedly, on rocks, not on brush, but logs slip and slide and push steel around.
Jim
Jim
Yes there is going to be a lot of cross bracing added to the upper "BITE" jaw.
The attached photos were just to show the progress as it was being built.
This was a trail fit to check the Cylinder Geometry before adding the cross bracing.
   / Another Homemade Root Grapple !! #13
I'm impressed. Kinda reminds me of a MAD MAX movie. Real mean lookin! :cool:
Had a chance to work more on the grapple this past weekend.
Added lateral tubes on the upper jaws for support. I still have plans to add 3/8" x 1.5" bar on the face of the jaws and a couple pieces between the Lat Tubes.
Here are some pics of the progress.
Dan.
Here is a shot fully open in upright position and a shot in the "BITE" position.
I measured it while open, and it has a whopping 91" open bite.
A shot of the first "VICTIM" :D:D .
My Uncle laughed and said it looked like I was carrying a ToothPick.
The Cylinders came with grease fittings installed. I had to make a Grease fitting for the pivot point on the Upper arms.
I tucked them back in a "Protected" area so hopefully no Brush will find them.
1st pic is the jaw closed .
2nd is the jaw open ready for a bite.
Paint will be coming soon.. I have yet to decide if I am going with NH BLUE Cylinders and Flat Black on the Grapple.
Or
Flat Black on everything ???
   / Another Homemade Root Grapple !! #19
Deerehunter, Nice job. I like the open toothed design, lets dirt & rocks drop out better than a bucket grapple & keeps logs closer to the loader arms -less stress on the roll cylinders. Also like the "tree getter" bracing between the teeth. I would take a grinder & undercut them a little for better grip. What's it weigh? MikeD74T
MikeD ,,
I have plans to bevel the "Tree Getter" supports.
As to the weight of the Grapple, that is a good ?? .
The cylinders combined weigh 49lbs , The teeth are 1/2" thick , the Lateral Tubes are 3.5" Dia 1/4" wall, all other steel is 3/8" thick.
I have to measure it up and calculate the Sq Ft of material used. I know that 1 Sq Ft of 1" in thick of mild steel weighs 40 lbs.
The next time I am at the property where the grapple is I will measure it up and calculate a rough weight of the completed project.
2017 FORD F550 CAB & CHASSIS (INOPERABLE) (A58214)
2017 FORD F550 CAB...
EZ-GO Utility Cart (A55853)
EZ-GO Utility Cart...
CHANDLER 500 BBL FRAC TANK (A58214)
CHANDLER 500 BBL...
Forklift Safety Basket (A56857)
Forklift Safety...
2007 Terex (A55973)
2007 Terex (A55973)
2018 HINO 338 KNUCKLE BOOM TRUCK (A51406)
2018 HINO 338...
