Another Homemade Root Grapple !!
   / Another Homemade Root Grapple !! #11
I like the big bite you can get - good for bushy tree limbs. I'd be concerned the arms would bend unless you are planning cross-bracing. It's funny how sideways things get even when you think you're biting evenly. I know the much shorter arms on my Millonzi are braced almost to the end, and they have bent a little. Admittedly, on rocks, not on brush, but logs slip and slide and push steel around.
Jim
Jim
Yes there is going to be a lot of cross bracing added to the upper "BITE" jaw.
The attached photos were just to show the progress as it was being built.
This was a trail fit to check the Cylinder Geometry before adding the cross bracing.
   / Another Homemade Root Grapple !! #13
I'm impressed. Kinda reminds me of a MAD MAX movie. Real mean lookin! :cool:
Had a chance to work more on the grapple this past weekend.
Added lateral tubes on the upper jaws for support. I still have plans to add 3/8" x 1.5" bar on the face of the jaws and a couple pieces between the Lat Tubes.
Here are some pics of the progress.
Dan.
Here is a shot fully open in upright position and a shot in the "BITE" position.
I measured it while open, and it has a whopping 91" open bite.
A shot of the first "VICTIM" :D:D .
My Uncle laughed and said it looked like I was carrying a ToothPick.
The Cylinders came with grease fittings installed. I had to make a Grease fitting for the pivot point on the Upper arms.
I tucked them back in a "Protected" area so hopefully no Brush will find them.
1st pic is the jaw closed .
2nd is the jaw open ready for a bite.
Paint will be coming soon.. I have yet to decide if I am going with NH BLUE Cylinders and Flat Black on the Grapple.
Or
Flat Black on everything ???
   / Another Homemade Root Grapple !! #19
Deerehunter, Nice job. I like the open toothed design, lets dirt & rocks drop out better than a bucket grapple & keeps logs closer to the loader arms -less stress on the roll cylinders. Also like the "tree getter" bracing between the teeth. I would take a grinder & undercut them a little for better grip. What's it weigh? MikeD74T
MikeD ,,
I have plans to bevel the "Tree Getter" supports.
As to the weight of the Grapple, that is a good ?? .
The cylinders combined weigh 49lbs , The teeth are 1/2" thick , the Lateral Tubes are 3.5" Dia 1/4" wall, all other steel is 3/8" thick.
I have to measure it up and calculate the Sq Ft of material used. I know that 1 Sq Ft of 1" in thick of mild steel weighs 40 lbs.
The next time I am at the property where the grapple is I will measure it up and calculate a rough weight of the completed project.
2014 FREIGHTLINER  CASCADIA (INOPERABLE) (A58214)
2014 FREIGHTLINER...
2014 Ford Fusion Passenger Car, VIN # 1FA6P0H77E5377755 (A56859)
2014 Ford Fusion...
John Deere 1025R (A53317)
John Deere 1025R...
EZ-GO golf cart (A56859)
EZ-GO golf cart...
Massey Ferguson 1745 Hesston series (A53317)
Massey Ferguson...
2008 Jeep Wrangler 4X4 SUV (A56859)
2008 Jeep Wrangler...
