Another home made cab tread
   / Another home made cab tread #1
Kiotikarl
Quebec Canada
2010 Kioti ck30 gear
With winter on it's way, and having sold the DK45SEC i had no other option than to custom build a cab. My cab will and must have the following;
-Heater
-Front and rear wiper
-Front and rear cab lights
-Dome lamp
-Lower than the Rops ( Rops cut down 11 inchs upon purchase)
-A radio
-Must be easily removable
-Wide enough to allow to bring a friend along:laughing:
Having seen many others build their own cab, i felt inspired to give it a try. I have lots of tools for the job, but lack the experience (cab 101:confused2:) So far this is what i have come up with, any comments/advice is more than welcome:thumbsup:
   / Another home made cab tread #2
-Heater
-Dome lamp
-A radio
A link to my blog which has a pretty detailed article about building a cab very much like yours. It was written with the idea of helping someone just like yourself. Translated, learn from my mistakes.(-:
Life on Highway 9: Building a tractor cab.
I like your door opening, nice and wide. I might have gone a size up on your square tubing.
Best tip I can give you is on weatherstripping, go to a old fashion junkyard that will let you wander around and check into the weatherstripping between the hood and the fire wall. Also check the trunk for weatherstripping. Some nice stuff cheap.
Fellow just posted a build on Bobcat tractor cab he built, study his build closely also, very nice.
Wipers, marine supply or 93 Dakota.
Sounds like you had cab before? Are the rear wipers really that helpful? Curious.
Headphone radio is the most practical in my book, noise level is going to be high, least is in mine.
Can't quite see your mounting points. Mine mounts down low on frt. then has rubber mounts at back, other then those points no contact between cab and tractor other then weatherstripping.
After finishing mine I noted a utility body in our shop which had very nice weatherstripping which sealed the side doors. This stuff would have worked good for sealing my door and window, never found it on the net but the utility box company is just down the road so could have got product or at least name from them.
Checkout those junkyard hood and trunk seals though. All kinds of different ones, 180 degree, 90 degree, big ones, small ones. You will be much happier with your cab if it seals tight.
Also take note on the blog of method used to seal under and behind seat, the rubber matting worked very well, simple, cheap, looks great.
Also note in the blog about building the door and window, tack weld shims in the openings, fit the window using the shims as spacers, clamp the four pieces into place, tack weld then you can pull it out and weld on the bench.
Happy building. Roy
Thanks Roy for the info, great looking cab also:thumbsup:
I will use weather stripping from a Ford Ranger for the door and side window. For the cowl/hood section it comes off a Dodge Caravan.
I did purchase the heater and wiper kits from the auto parts store, very expensive:( but worth it. The wiper motor is 2 speed, and ajustable swipe.
I did make cab mounts which are bolted to the FEL/BH brackets.
   / Another home made cab tread #4
Looks to be a good start, Kiotikarl!
I'll be watching this thread!
   / Another home made cab tread #5
Hey, good progress, like the way your fill in around the fenders is coming out. Again, envy the space you have for your door, mine was so tight. For sure keep the updates coming, gets my blood pumping.
   / Another home made cab tread #6
can you tell me the brand/model# of your wiper. looks like something i could use to replace my crapped out surplus center wiper. also which auto parts store did you find it at. thank you and good job so far on your cab. something to be very proud of every time you use it. will enjoy following your build. we are still waiting for snow here. never snows enough once you own the right tool to deal with winter conditions.
   / Another home made cab tread #7
It already looks to good to be called home made, that sounds inferior when referring to a cab, but yours is starting to look factory.
JB
Update on the cab project, have the top done and wire ready for lights and all. Got the led dome light installed. It's almost paint shop ready, i did the cab interior myself.
Now to answer a few questions;)
The wiper motors are from Cadel (uni-select auto parts found that on the net, could of done that myself.)
Motor #WWF12C18720S
Wiper blade arm (ajustable from 14-19 inchs) #LE5810222S
Wiper blade 18 inches # 134000000
Don't know if these are the right part #:laughing:, but thats what is on the bill;)
I also got the switchs installed and the fuse box.
Thanks so far for the comments.
One question i was thinking about last night (or early this morning:D) i wonder if i will need to replace the alternator with all the extra electrical accessories, i believe the oem is a 50amp.:confused:
2018 FORD F150 XL TRUCK (A51406)
2018 FORD F150 XL...
2013 Yale GLC050LXNVAE087 5,000lbs Propane Cushion Tire Forklift (A51691)
2013 Yale...
DROME EXCAVATOR SLIDE ATTEHMENT (A50322)
DROME EXCAVATOR...
2021 Kubota RTV-X1140RL-A (A47384)
2021 Kubota...
2020 Can-Am Ryker Rally 900 Ace 3-Wheeled Motorcycle (A51694)
2020 Can-Am Ryker...
2009 JLG 1930ES ELECTRIC SCISSOR LIFT (A51242)
2009 JLG 1930ES...
